Is the LINE widget has the shadow style properties? If not, how to achieve property of shadow?
Before posting
IMXRT1052
V8
Property of shadow with LINE widget
There is no shadow property for a line. What you can do is drawing a line on a canvas and blur it.
See this example as a reference.
Thanks,
This way is useful, but when i rotating the canvas causes a splash screen. The canvas buf used “LV_CANVAS_BUF_SIZE_TRUE_COLOR_ALPHA” , and LV_COLOR_DEPTH = 16.
Solved!The previous error is because i didn’t keep cbuf_tmp and cbuf as same size .
