Before posting
ESP32-S3
v8.3.2
Display values in a point location in a chart
Attempted to import coordinate values with function lv_chart_get_point_pos_by_id().
However, the coordinate values are expressed strangely.
lv_obj_t * panel1 = lv_obj_create(lv_scr_act());
lv_obj_remove_style_all(panel1);
lv_obj_set_size(panel1, 420, 380);
lv_obj_set_pos(panel1, 60, 0);
lv_obj_add_style(panel1, &Weather_Value_Style, 0);
lv_obj_set_scroll_dir(panel1, LV_DIR_LEFT | LV_DIR_RIGHT);
static lv_style_t chart_style;
lv_style_init(&chart_style);
lv_style_set_border_color(&chart_style, lv_color_white());
lv_obj_t * chart;
chart = lv_chart_create(panel1);
lv_chart_set_div_line_count(chart, 0, 0);
lv_obj_set_pos(chart, 15, 130);
lv_obj_add_style(chart, &chart_style, 0);
lv_chart_series_t * ser1 = lv_chart_add_series(chart, lv_palette_main(LV_PALETTE_BLUE), LV_CHART_AXIS_PRIMARY_Y);
lv_chart_set_point_count(chart, 72);
lv_chart_set_type(chart, LV_CHART_TYPE_LINE);
int Axis_X = -180;
for(int i = 0; i < 72; i++){
if(i != 0)Axis_X += 60;
lv_obj_t *Weather_Value_Time_Text = lv_label_create(panel1);
lv_label_set_text_fmt(Weather_Value_Time_Text, "%d시", Hour_data[i]);
lv_obj_set_style_text_align(Weather_Value_Time_Text, LV_TEXT_ALIGN_CENTER, 0);
lv_obj_align(Weather_Value_Time_Text, LV_ALIGN_CENTER, Axis_X, -140);
lv_obj_t *Weather_Value_Img = lv_img_create(panel1);
if(Weather_data[i] == 1){
if(Hour_data[i] < 8 || Hour_data[i] > 17)lv_img_set_src(Weather_Value_Img, &Clear_N);
else lv_img_set_src(Weather_Value_Img, &Clear_S);
if(Weather_data[i] == 2){
if(Hour_data[i] < 8 || Hour_data[i] > 17)lv_img_set_src(Weather_Value_Img, &Mostly_Cloudy_N);
else lv_img_set_src(Weather_Value_Img, &Mostly_Cloudy_S);
if(Weather_data[i] == 3)lv_img_set_src(Weather_Value_Img, &Cloudy);
if(Weather_data[i] == 4)lv_img_set_src(Weather_Value_Img, &Rain);
if(Weather_data[i] == 5)lv_img_set_src(Weather_Value_Img, &Rain_Snow);
if(Weather_data[i] == 6)lv_img_set_src(Weather_Value_Img, &Snow);
if(Weather_data[i] == 7)lv_img_set_src(Weather_Value_Img, &shower);
if(Weather_data[i] == 8)lv_img_set_src(Weather_Value_Img, &Raindrop);
if(Weather_data[i] == 9)lv_img_set_src(Weather_Value_Img, &Raindrop_Snow);
if(Weather_data[i] == 10)lv_img_set_src(Weather_Value_Img, &Snow_Drifting);
lv_obj_align(Weather_Value_Img, LV_ALIGN_CENTER, Axis_X, -90);
lv_chart_set_next_value(chart, ser1, Temp_data[i]);
lv_obj_t *Weather_Value_Humidity_Text = lv_label_create(panel1);
lv_label_set_text_fmt(Weather_Value_Humidity_Text, "%d%%", Humidity_data[i]);
lv_obj_set_style_text_align(Weather_Value_Humidity_Text, LV_TEXT_ALIGN_CENTER, 0);
lv_obj_align(Weather_Value_Humidity_Text, LV_ALIGN_CENTER, Axis_X, 60);
lv_obj_t *Weather_Value_Rain_Text = lv_label_create(panel1);
float rain = Rain_data[i];
if(rain == 0)lv_label_set_text(Weather_Value_Rain_Text, "-");
if(rain > 0 && rain < 1)lv_label_set_text(Weather_Value_Rain_Text, "~1");
if(rain >= 1){
char rain_str[10];
if (rain == static_cast<int>(rain))snprintf(rain_str, sizeof(rain_str), "%d", static_cast<int>(rain));
else dtostrf(rain, 4, 1, rain_str);
const char* rain_const = rain_str;
lv_label_set_text(Weather_Value_Rain_Text, rain_const);
lv_obj_set_style_text_align(Weather_Value_Rain_Text, LV_TEXT_ALIGN_CENTER, 0);
lv_obj_align(Weather_Value_Rain_Text, LV_ALIGN_CENTER, Axis_X, 110);
lv_obj_t *Weather_Value_Rain_Per_Text = lv_label_create(panel1);
lv_label_set_text_fmt(Weather_Value_Rain_Per_Text, "%d%%", Rain_Per_data[i]);
lv_obj_set_style_text_align(Weather_Value_Rain_Per_Text, LV_TEXT_ALIGN_CENTER, 0);
lv_obj_align(Weather_Value_Rain_Per_Text, LV_ALIGN_CENTER, Axis_X, 160);
lv_chart_set_range(chart, LV_CHART_AXIS_PRIMARY_Y, low_temp, high_temp + 5);
lv_obj_set_size(chart, Axis_X+200, 110);
lv_chart_refresh(chart);
lv_point_t p;
lv_chart_get_point_pos_by_id(chart, ser1, i, &p);
Serial0.print(“i:”);Serial0.print(i);
Serial0.print(“, x:”);Serial0.print(p.x);
Serial0.print(“, y:”);Serial0.println(p.y);
lv_obj_t *Weather_Temp_Text = lv_label_create(chart);
lv_label_set_text_fmt(Weather_Temp_Text, “%d”, Temp_data[i]);
lv_obj_set_style_text_align(Weather_Temp_Text, LV_TEXT_ALIGN_CENTER, 0);
lv_obj_set_pos(Weather_Temp_Text,p.x,p.y);
Serial print
i:0, x:12, y:3
i:1, x:12, y:3
i:2, x:12, y:1
i:3, x:11, y:1
i:4, x:11, y:0
i:5, x:11, y:-2
i:6, x:10, y:-2
i:7, x:10, y:-4
i:8, x:10, y:-6
i:9, x:9, y:-6
i:10, x:9, y:-6
i:11, x:9, y:-6
i:12, x:8, y:-6
i:13, x:8, y:-6
i:14, x:8, y:-6
i:15, x:7, y:-4
i:16, x:7, y:-6
i:17, x:7, y:-6
i:18, x:6, y:-6
i:19, x:6, y:-7
i:20, x:6, y:-7
i:21, x:5, y:-9
i:22, x:5, y:-7
i:23, x:5, y:-7
i:24, x:4, y:-9
i:25, x:4, y:-9
i:26, x:4, y:-9
i:27, x:3, y:-9
i:28, x:3, y:-11
i:29, x:3, y:-11
i:30, x:2, y:-11
i:31, x:2, y:-11
i:32, x:2, y:-11
i:33, x:1, y:-12
i:34, x:1, y:-11
i:35, x:1, y:-11
i:36, x:0, y:-9
i:37, x:0, y:-7
i:38, x:0, y:-7
i:39, x:-1, y:-6
i:40, x:-1, y:-6
i:41, x:-1, y:-7
i:42, x:-2, y:-7
i:43, x:-2, y:-9
i:44, x:-2, y:-9
i:45, x:-3, y:-9
i:46, x:-3, y:-9
i:47, x:-3, y:-9
i:48, x:-4, y:-11
i:49, x:-4, y:-11
i:50, x:-4, y:-11
i:51, x:-5, y:-11
i:52, x:-5, y:-12
i:53, x:-5, y:-12
i:54, x:-6, y:-12
i:55, x:-6, y:-12
i:56, x:-6, y:-12
i:57, x:-7, y:-12
i:58, x:-7, y:-11
i:59, x:-7, y:-9
i:60, x:-8, y:-7
i:61, x:-8, y:-6
i:62, x:-8, y:-4
i:63, x:-9, y:-4
i:64, x:-9, y:-4
i:65, x:-9, y:-4
i:66, x:-10, y:-4
i:67, x:-10, y:-6
i:68, x:-10, y:-7
i:69, x:-11, y:-7
i:70, x:-11, y:-9
i:71, x:-12, y:-11
