Before posting
I need to achieve an effect: when I turn the knob, the focus can go back and forth between the subtitle of the tabview and an image button
stm32f7
v8.0
At present, only the image button and the large column of the tabview can be moved. To enter the subtitle, you need to long press. After long pressing, you can only move between the subtitles.
tv = lv_tabview_create(lv_scr_act(), LV_DIR_TOP, 35);
lv_obj_set_style_bg_color(tv,COLOR_SCR_BG,0);
lv_obj_set_size(tv, LV_HOR_RES, LV_VER_RES - 20);
lv_obj_set_y(tv,20);
lv_obj_t * tab_btns = lv_tabview_get_tab_btns(tv);
lv_obj_set_style_bg_color(tab_btns, COLOR_SCR_BG, 0);
lv_obj_set_style_text_color(tab_btns, COLOR_SCR_TEXT, 0);
lv_obj_set_style_border_side(tab_btns, LV_BORDER_SIDE_BOTTOM, LV_PART_SELECTED | LV_STATE_FOCUSED);
lv_group_add_obj(group2,tab_btns);
lv_group_add_obj(group_tabviwe_000,tab_btns);
lv_group_add_obj(group_tabviwe_001,tab_btns);
lv_group_add_obj(group_tabviwe_002,tab_btns);
