Before posting
The current behavior is that if the scrolling is less than the size of one item, it gets attracted to the center position, causing a jittering effect. For a knob, if the scrolling pixel distance can be calculated, it will not scroll if it’s less than one item, but it will scroll by whole items if it’s more than one or several items, thereby achieving a stepping effect, which can provide a better user experience.
BES2700BP
LVGL 8.3.10
Is it possible to modify the scroll function implementation, or do you have any better suggestions?
Walk through the scrolling code and try to understand its logic.
lv_result_t _lv_obj_scroll_by_raw(lv_obj_t * obj, int32_t x, int32_t y)
if(x == 0 && y == 0) return LV_RESULT_OK;
lv_obj_allocate_spec_attr(obj);
obj->spec_attr->scroll.x += x;
obj->spec_attr->scroll.y += y;
lv_obj_move_children_by(obj, x, y, true);
lv_result_t res = lv_obj_send_event(obj, LV_EVENT_SCROLL, NULL);
if(res != LV_RESULT_OK) return res;
lv_obj_invalidate(obj);
