I want to achieve a sliding function similar to the one shown in the figure below, is there a demo reference?
Before posting
esp32
V7.x
I want to achieve a sliding function similar that can show menu image like the wathch
Do you also want the selected image scale smoothly as it approaches the center?
Anyway, in v it’d be much simpler. In v8 there is
  • snapping to automatically snap children to the center of the parent
  • events on scrolling to change zoom based on the current x position
So is is it an option to update to v8?
thank you for your reply
yeap,now I had update the version to v8,and what I want to do is as you said “selected image scale smoothly as it approaches the center”
but my question is below:
1、how can I get the x position of an image
2、And I am using the encoder but not touch pad,how to set the image obj to be controled by encoder or keys
I think you need to combine these two examples:
thanks a lot
Hi @Kingwulin,
Were you able to achieve above scrolling menu?
Can you please share how you have achieved this?
Thanks
