I hope the chart widgets can specify the position of the every point X-axis as well, because in practice, x’s are not equally spaced in most scenarios.
- Please refer to emwin or QT for this function is required.
Just in Scatter Chart you can set X and Y using lv_chart_set_next_value2 but they are not connected.
So do you need functions like these?
lv_chart_set_value_x(chart, ser, point_index, value);
lv_chart_set_value_y(chart, ser, point_index, value);
That’s fine ,but I don’t care how to call it, I just need to draw a curve on the chart that specifies the XY of each point.
But the gist is to have separate functions for x and y instead of a set_xy
function, right?
It’s better to have both and I suggest managing this curve with a float two-dimensional array.
Such as
curve = {{X0,Y0},{X1,Y1},{X2,Y2},{X3,Y3},…}
There is no float in lvgl but you can use lv_chart_set_ext_y_array
and lv_chart_set_ext_x_array
to set your own array or use lv_chart_get_y_array
and lv_chart_get_x_array
to get the array where lvgl stores the values.
Ok, so when will the function of the curve be added?
I’m a little bit confused. It seems to me you can use the functions mentioned here and they already exist.
The method you provided does not meet my requirements,I just need to draw a curve on the chart that specifies the XY of each point…maybe what I need is
void lv_chart_set_next_value(lv_obj_t * obj, lv_chart_series_t * ser, lv_coord_t x, lv_coord_t y)
*Sorry to bother you so long, but I really want to find what I’m looking for。
void lv_chart_set_next_value2(lv_obj_t * obj, lv_chart_series_t * ser, lv_coord_t x_value, lv_coord_t y_value)
I have one last question. Can the code I wrote in version 7 be used in version 8?
Yes and no. The two versions are not completely incompatible, but you will need to make substantial modifications for the new style & event APIs.
