I have some suggestions about chart
I hope the chart widgets can specify the position of the every point X-axis as well, because in practice, x’s are not equally spaced in most scenarios.
  • Please refer to emwin or QT for this function is required.
his feature exists in v8.
See the Scatter chart example: Examples — LVGL documentation
Just in Scatter Chart you can set X and Y using lv_chart_set_next_value2 but they are not connected.
So do you need functions like these?
lv_chart_set_value_x(chart, ser, point_index, value);
lv_chart_set_value_y(chart, ser, point_index, value);
That’s fine ,but I don’t care how to call it, I just need to draw a curve on the chart that specifies the XY of each point.
But the gist is to have separate functions for x and y instead of a set_xy function, right?
It’s better to have both and I suggest managing this curve with a float two-dimensional array.
Such as
curve = {{X0,Y0},{X1,Y1},{X2,Y2},{X3,Y3},…}
There is no float in lvgl but you can use lv_chart_set_ext_y_array and lv_chart_set_ext_x_array to set your own array or use lv_chart_get_y_array and lv_chart_get_x_array to get the array where lvgl stores the values.
Ok, so when will the function of the curve be added?
I’m a little bit confused. It seems to me you can use the functions mentioned here and they already exist.
  • All right, I’ll try to make a curve with them
The method you provided does not meet my requirements,I just need to draw a curve on the chart that specifies the XY of each point…maybe what I need is
void lv_chart_set_next_value(lv_obj_t * obj, lv_chart_series_t * ser, lv_coord_t x, lv_coord_t y)
*Sorry to bother you so long, but I really want to find what I’m looking for。
void lv_chart_set_next_value2(lv_obj_t * obj, lv_chart_series_t * ser, lv_coord_t x_value, lv_coord_t y_value)
I have one last question. Can the code I wrote in version 7 be used in version 8?
Yes and no. The two versions are not completely incompatible, but you will need to make substantial modifications for the new style & event APIs.
