Before posting
I’m coding a screen transition program using ESP32 and ili9488.
I had chat gpt create a sample program for simple screen transitions, but I cannot switch to the next screen even if I press the next button.
I found that the return value of lv_obj_get_user_data of the called handler was NULL.
ESP32 & ili9488
v8.3.9
I want to move to the next screen.
I would like to know if there is really no problem with this coding.
(lv_obj_t *)lv_obj_get_user_data(btn)
I see that this return value is NULL.
void screen_setup() {
//lv_init();
//ili9488_init();
screen1 = lv_obj_create(NULL);
create_keypad_screen(screen1);
screen2 = lv_obj_create(NULL);
create_clock_screen(screen2);
screen3 = lv_obj_create(NULL);
create_security_screen(screen3);
screen4 = lv_obj_create(NULL);
create_fourth_screen(screen4);
lv_scr_load(screen1);
lv_timer_create(update_clock, 1000, NULL);
void add_navigation_buttons(lv_obj_t *scr, lv_obj_t *next_screen, lv_obj_t *prev_screen) {
lv_obj_t *btn_next = lv_btn_create(scr);
lv_obj_set_size(btn_next, 100, 50);
lv_obj_align(btn_next, LV_ALIGN_BOTTOM_RIGHT, -10, -10);
lv_obj_set_user_data(btn_next, next_screen);
lv_obj_add_event_cb(btn_next, btn_event_cb, LV_EVENT_CLICKED, NULL);
lv_obj_t *label_next = lv_label_create(btn_next);
lv_label_set_text(label_next, "Next");
lv_obj_t *btn_back = lv_btn_create(scr);
lv_obj_set_size(btn_back, 100, 50);
lv_obj_align(btn_back, LV_ALIGN_BOTTOM_LEFT, 10, -10);
lv_obj_set_user_data(btn_back, prev_screen);
lv_obj_add_event_cb(btn_back, btn_event_cb, LV_EVENT_CLICKED, NULL);
lv_obj_t *label_back = lv_label_create(btn_back);
lv_label_set_text(label_back, "Back");
void btn_event_cb(lv_event_t *e) {
Serial.println("btn_event_cb start");
#if 1
lv_obj_t *btn = lv_event_get_target(e);
// デバッグ情報の出力
if (btn != NULL) {
Serial.println("Event target (button) is not NULL");
// さらに、ボタンに関する詳細情報を出力できます
} else {
Serial.println("Event target (button) is NULL");
lv_obj_t *next_screen = (lv_obj_t *)lv_obj_get_user_data(btn);
// デバッグ情報の出力
if (next_screen != NULL) {
Serial.println("next_screen is not NULL");
lv_scr_load(next_screen);
} else {
Serial.println("next_screen is NULL");
Serial.println("next_screen");
Serial.println("btn_event_cb end");
