Before posting
iMX93 evk
8.3.5
I want to display 5 screen after every 2 mints in loop like screen -1,2,3,1,2,3… and read data from ZMQ dealer thread and display on UI.
I have created one thread for ZMQ dealer and another(data_display_thread) for parsing data received from ZMQ and display on . but ZMQ data received thread reciving data correctly but when I call any LVGL APIs they are not working in “data_display_thread”
In event.c
static void main_event_handler (lv_event_t *e)
switch (code) {
case LV_EVENT_SCREEN_LOADED:
switch_scr=lv_timer_create(switch_screen, 3000, &guider_ui);
main_init();
break;
case LV_EVENT_SCREEN_UNLOAD_START:
lv_timer_del(switch_scr);
break;
default:
break;
In Custom.c
void main_init(void)
printf("main init \n");
bool status ;
status = pthread_create(&screen_display, NULL,switch_screen_thread, NULL);
status = ZMQ_Rec();
printf("return from ZMQ recive\n");
static void *switch_screen_thread(void *arg)
printf("In screen display\n");
phase_A.Phase_Voltage=10;phase_B.Phase_Voltage=11;phase_C.Phase_Voltage=12;
while (1)
phase_A.Phase_Voltage++;phase_B.Phase_Voltage++;phase_C.Phase_Voltage++;
/* Set the poll item */
pthread_mutex_lock(&mutex); // Acquire the mutex
printf("In Mutex \n");
usleep(10 * 1000);
lv_label_set_text_fmt(guider_ui.Home_PHA_volt, "%d",phase_A.Phase_Voltage);
usleep(10 * 1000); printf("after volt A\n");
lv_label_set_text_fmt(guider_ui.Home_PHB_volt, "%d",phase_B.Phase_Voltage);
usleep(10 * 1000); printf("after volt B \n");
lv_label_set_text_fmt(guider_ui.Home_PHC_volt, "%d",phase_C.Phase_Voltage);
lv_task_handler();
usleep(10 * 1000); printf("after volt C \n");// Sleep for 10ms
// task_meter1 =lv_timer_create(current_meter_timer_cb, 5000, &guider_ui);
pthread_mutex_unlock(&mutex); // Release the mutex
// printf("after Mutex \n");
// lv_timer_del(task_meter1 );
return 0;
int ZMQ_Rec(void)
if( SUCCESS == Display_ZMQInit()){
pthread_join(tid, NULL);
pthread_join(screen_display, NULL);
In above code all print message are coming but display on screen or change in screen not happing. please help it urgent
## Screenshot and/or video
