Before posting
STM32L476RG
v8.3
I want to convert it to another image when I press the button. However, read_cb does not work when the button is pressed.
void button(void)
static lv_indev_t *indev;
lv_indev_drv_t indev_drv;
//Register a button input device
indev_drv.type = LV_INDEV_TYPE_BUTTON;
indev_drv.read_cb = input_read;
indev = lv_indev_drv_register(&indev_drv);
static const lv_point_t btn_points_1[1] = {
{120, 90} //Button 0 -> x:10; y:10//
lv_indev_set_button_points(indev_button_1, btn_points_1);
lv_obj_t *btn = lv_btn_create(lv_scr_act());
lv_obj_set_size(btn, 40, 40);
lv_obj_set_pos(btn, 0, 0);
lv_obj_add_event_cb(btn, btn_event_handler, LV_EVENT_ALL, NULL);
static int8_t button_get_pressed_id_1(void)
uint8_t i;
//Check to buttons see which is being pressed (assume there are 2 buttons)//
for(i = 0; i < 1; i++) {
//Return the pressed button's ID//
if(button_is_pressed_1(i)) {
return i;
//No button pressed//
return -1;
//Test if `id` button is pressed or not//
static bool button_is_pressed_1(uint8_t id)
if(id == 0)
if(HAL_GPIO_ReadPin(USER_BUTTON_GPIO_Port, USER_BUTTON_Pin) == GPIO_PIN_RESET)
return true;
else if(HAL_GPIO_ReadPin(USER_BUTTON_GPIO_Port, USER_BUTTON_Pin) == GPIO_PIN_SET)
return false;
return false;
uint8_t btn_read(void) {
if(HAL_GPIO_ReadPin(USER_BUTTON_GPIO_Port, USER_BUTTON_Pin) == 0){
HAL_GPIO_WritePin(GREEN_LED_GPIO_Port, GREEN_LED_Pin, GPIO_PIN_SET);
return 1;
return 0;
static void btn_event_handler(lv_event_t * e)
//Original Code
if(code == LV_EVENT_PRESSED)
//Turn the LED ON
// lv_led_on(led1);
lv_label_set_text(label, "Pressed"); //Set the labels text//
lv_obj_center(label);
// lv_label_set_text(labelCounter, "Something Pressed !!!"); //For debugging
else if(code == LV_EVENT_RELEASED)
//Turn the LED OFF
HAL_GPIO_WritePin(GREEN_LED_GPIO_Port, GREEN_LED_Pin, GPIO_PIN_RESET);
// lv_led_off(led1);
lv_label_set_text(label, "Nothing Pressed "); //Set the labels text//
// lv_label_set_text(labelCounter, "Nothing Pressed"); //For debugging
