How to use canvas in a screen higher than 2048 pixels(the max height of the image in lvgl)?
Before posting
I want to draw some lines in the screen with lv_canvas, but when set buffer to the canvas i found that the max width/height of the image map is 2048:
typedef struct {
uint32_t cf : 5;
uint32_t always_zero : 3;
uint32_t reserved : 2;
uint32_t w : 11;
uint32_t h : 11;
} lv_img_header_t;
Thus if i set the height as 2400. it turns out to be 352.
Is there any way to solve the problem?
7.4
It’s really a limitation even in v8. In v9 it will be improved. Until that you can change
uint32_t w : 11;
uint32_t h : 11;
to
uint32_t w : 12;
uint32_t h : 12;
but I haven’t tested if it really works.
