Before posting
masterbranch.- Be sure you have checked the relevant part of the documentation.
arm with embedded Linux
V7
using File as an image button source.
first of all, I have initialized lvgl file system ( lv_fs_drv_t) and registered it.
second, convert a png file to a .binary file.
Third, use the path of the file as the source of a imgbtn object.
now the imgbtn appear for a few second and disappear with the “Segmentation fault” error.
in main fuction ==>
lv_fs_drv_t drv;
lv_fs_drv_init(&drv); /*Basic initialization*/
drv.letter = 'S'; /*An uppercase letter to identify the drive */
drv.file_size =2048;//sizeof(my_file_object); /*Size required to store a file object*/
//drv.rddir_size = sizeof(my_dir_object); /*Size required to store a directory object (used by dir_open/close/read)*/
/*Callback to tell if the drive is ready to use */
drv.open_cb = fs_open; /*Callback to open a file */
drv.close_cb = fs_fclose; /*Callback to close a file */
drv.read_cb = fs_fread; /*Callback to read a file */
drv.seek_cb = fs_fseek; /*Callback to seek in a file (Move cursor) */
drv.tell_cb = fs_ftell; /*Callback to tell the cursor position */
lv_fs_drv_register(&drv); /*Finally register the drive*/
declare of the function =>
static lv_fs_res_t fs_open (lv_fs_drv_t * drv, void * file_p, const char * path, lv_fs_mode_t mode)
lv_fs_res_t res = LV_FS_RES_NOT_IMP;
lv_fs_file_t * file_1 = (lv_fs_file_t *)file_p;
if(mode == LV_FS_MODE_WR)
file_1->file_d = fopen(path, "w");
else if(mode == LV_FS_MODE_RD)
file_1->file_d = fopen(path, "r");
else if(mode == (LV_FS_MODE_WR | LV_FS_MODE_RD))
file_1->file_d = fopen(path, "w+");
if(file_1->file_d == NULL)
return LV_FS_RES_FS_ERR;
return LV_FS_RES_OK;
lv_fs_res_t fs_fread(struct _lv_fs_drv_t * drv, void * file_p, void * buf, uint32_t btr, uint32_t * br)
*br = fread(buf, 1, btr, file_1->file_d);
printf("br = %d\n", *br);
return 0;
lv_fs_res_t fs_fclose(struct _lv_fs_drv_t * drv, void * file_p)
printf("close file\n");
fclose(file_1->file_d);
return 0;
static lv_fs_res_t fs_fseek (lv_fs_drv_t * drv, void * file_p, uint32_t pos)
printf("fseek pos=%d\n",pos);
fseek(file_1,pos,SEEK_SET);
res = LV_FS_RES_OK;
return res;
later in main fuction ==>
lv_obj_t * mainmenuPanel[6];
lv_obj_t * mainmenuBtn[6];
lv_obj_t * mainmenuLabel[6];
for(ii=0 ; ii < 6 ; ii++)
mainmenuPanel[ii] = lv_cont_create(win,NULL);
lv_obj_set_size(mainmenuPanel[ii],220,84);
mainmenuBtn[ii] = lv_imgbtn_create(mainmenuPanel[ii],NULL);
lv_obj_set_size(mainmenuBtn[ii],64,64);
mainmenuLabel[ii] = lv_label_create(mainmenuPanel[ii],NULL);
lv_obj_set_style_local_bg_opa(mainmenuBtn[ii],LV_CONT_PART_MAIN,LV_STATE_DEFAULT,0);
lv_obj_set_style_local_border_opa(mainmenuPanel[ii],LV_CONT_PART_MAIN,LV_STATE_DEFAULT,0);
lv_obj_set_style_local_bg_opa(mainmenuPanel[ii],LV_CONT_PART_MAIN,LV_STATE_DEFAULT,0);
lv_obj_align(mainmenuPanel[ii],NULL,LV_ALIGN_IN_TOP_LEFT, 32+(/*800/3*/ 210 ) * (ii%3), 64+(32+400/4) * (ii / 3) );
lv_obj_align(mainmenuBtn[ii],NULL,LV_ALIGN_IN_TOP_MID, 0,0 );
lv_obj_align(mainmenuLabel[ii],NULL,LV_ALIGN_IN_BOTTOM_MID, 0,0 );
lv_imgbtn_set_src(mainmenuBtn,LV_BTN_STATE_PRESSED,"S/images/MainMenu_Record_888.bin");
lv_imgbtn_set_src(mainmenuBtn,LV_BTN_STATE_RELEASED,"S/images/MainMenu_Record_888.bin");
the image button appears for a few second and then system crashes
