How to update x axis from data array
i am receiving 5 values i would like to plot, the are for example val1 to val4 with one value representing the time stamp. All the four values have the same time stamp since they are received at the same time. I found the lv_chart that i tried using but the examples don’t really illustrate what i want to do. what i want is to plot the 4 values (y axis) and their time stamp( x axis).
i am using an esp32-s3 N16R8. I am writing the code in platformIO IDE with the Arduino framework
the LGLV version is 9.1.0
i want the graph to be updated when the new values arrive and to shift them to the left as well as the axis just like any other graph.
some way to control the values of the x axis
i have tried the LVGL chart widget, and from what i understood, the function lv_chart_set_next_value() only changes the y->points, as shown in the lv_chart.h fiel. I can display data on the graph but I don’t know how to access the x values.
/*void add_data_to_chart(){
  lv_chart_series_t * ser1 = lv_chart_add_series(objects.data_graph, lv_palette_main(LV_PALETTE_GREEN), LV_CHART_AXIS_PRIMARY_Y);
  lv_chart_series_t * ser2 = lv_chart_add_series(objects.data_graph, lv_palette_main(LV_PALETTE_BLUE), LV_CHART_AXIS_PRIMARY_Y);
  lv_chart_series_t * ser3 = lv_chart_add_series(objects.data_graph, lv_palette_main(LV_PALETTE_RED), LV_CHART_AXIS_PRIMARY_Y);
  lv_chart_series_t * ser4 = lv_chart_add_series(objects.data_graph, lv_palette_main(LV_PALETTE_INDIGO), LV_CHART_AXIS_PRIMARY_Y);
  int32_t * ser2_y_points = lv_chart_get_y_array(objects.data_graph, ser2);
  uint32_t i;
  for(i = 0; i < 10; i++) {
    /*Set the next points on 'ser1'*/
    lv_chart_set_next_value(objects.data_graph, ser1, ui_val1);
    lv_chart_set_next_value(objects.data_graph, ser2, ui_val2);
    lv_chart_set_next_value(objects.data_graph, ser3, ui_val3);
    lv_chart_set_next_value(objects.data_graph, ser4, ui_val4);
  lv_chart_refresh(objects.data_graph); /*Required after direct set*/
Perhaps you can try lv_chart_set_next_value2(lv_obj_t *obj, lv_chart_series_t *ser, int32_t x_value, int32_t y_value)
this function only works for scatter type charts that’s why I didn’t try it
I think you might need to start using the draw callback for the graph and update the labels while the screen is being drawn.
Here is my research into this (works for 8.3 and 8.4)
I see that the lv_chart_set_axis_tick is used a lot, but it’s not available with lvgl 9.1. I see that in your code you set an external array for y, but what about x? If the data I am trying to plot was very periodic then i wouldn’t mind the x values, but since it’s not the case for me i wanted to find another way. maybe i need to look deeper in the documentation to understand how this chart widget works
It seems that this has been replaced with the “scale” widget.
See also.
https://docs.lvgl.io/master/widgets/scale.html
yes i was able to realize the idea i had in mind with the scale widget. the x axis labels shift to the left while the new data is being plotted.
thank you
