Before posting
8.3
There are 2 lv_obj_t objects, A_screen and B_screen, the codes switch them by events as follows.But the system crashed after more 100 times switch. Is it memory leak?
if(event1)
lv_obj_clean(A_screen);
ui_init(B_screen);
}else if(event2)
lv_obj_clean(B_screen);
ui_init(A_screen);
## Screenshot and/or video
