Before posting
IMXRT1052
V8
I want make a animation of opa , the end of the opa is not 100% , but the image’s opa is 100% automatic.
void lv_obj_fade(lv_obj_t * obj, uint32_t time, uint32_t delay,uint8_t opa_start,uint8_t opa_end)
lv_anim_t a;
lv_anim_init(&a);
lv_anim_set_path_cb(&a, lv_anim_path_ease_in_out );
lv_anim_set_var(&a, obj);
lv_anim_set_values(&a, opa_start, opa_end);
lv_anim_set_exec_cb(&a, fade_anim_cb);
lv_anim_set_ready_cb(&a, fade_in_anim_ready);
lv_anim_set_time(&a, time);
lv_anim_set_delay(&a, delay);
lv_anim_start(&a);
