How to solve the split screen problem?
Before posting
I am using lvgl to create UI interface, but I have encountered strange problems. Since I just came into contact with lvgl8.2, I only wanted to display one icon on the interface at first, but I found that the screen interface was divided into two parts. I only created one icon, but two icons were displayed, and it can be seen that the width of the icon has become half. How to solve this problem?
lvgl8.2
static lv_color_t* disp_buf1;
void display_init()
fbdev_init();
disp_buf1 = (lv_color_t*)malloc(HOR_RES VER_RESsizeof(lv_color_t));
lv_disp_draw_buf_init(&draw_buf, disp_buf1, NULL, HOR_RES * VER_RES);
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = HOR_RES;
disp_drv.ver_res = VER_RES;
void create_ui()
lv_obj_t* label = lv_label_create(lv_scr_act());
lv_label_set_text(label, LV_SYMBOL_OK);
lv_obj_set_style_text_font(label, &lv_font_montserrat_32, 0);
Sloved.
The device screen is 32bpp,but i set LV_COLOR_DEPTH 16 in lv_conf.h.
