Before posting
Hey here.
I truly believe that I got some problems confusing me.I’ve tried using multi-threads recently,yet I’m not the person mastering of multi-threads.And the dilmma of the kind fast animation beyond expectation confused me so much.
As my following code,I changed animation duration time according to definite ratio of tick time and handler sleep time(though,I dont know whether it is right).
I hope someone can help me solve this issue.Thanks so much!!
I guess it doesn’t matter.
released 8.3.0
Correct,normal animation show and speed in multi-threads situation.
Change tick time and enhance duration of animation and so on,but failed.
And I’ve looked up many references about this situation for answer,but it didn’t work.
/* Thread of tick */
pthread_mutex_t my_lvgl_mutex = PTHREAD_MUTEX_INITIALIZER;
pthread_t pthread_id_tick = 0;
void my_lvgl_lock()
pthread_mutex_lock(&my_lvgl_mutex );
void my_lvgl_unlock()
pthread_mutex_unlock(&my_lvgl_mutex );
/* Some macros */
#define TICK_INC_TIME 7
#define HANDLE_THREAD_SLEEP_TIME 1000
#define TICK_THREAD_SLEEP_TIME 1000
#define ANIM_LACK_TIMES ((TICK_INC_TIME * 1000 / TICK_THREAD_SLEEP_TIME))
#define ANIM_HALF_1_SEC (500 * ANIM_LACK_TIMES)
#define ANIM_1_SEC (1000 * ANIM_LACK_TIMES)
void *my_tick(void *arg)
pthread_detach(pthread_self());
while (1)
my_lvgl_lock();
lv_tick_inc(TICK_INC_TIME); // TICK_INC_TIME = 7
my_lvgl_unlock();
usleep(TICK_THREAD_SLEEP_TIME); // TICK_THREAD_SLEEP_TIME = 1000
return ((void *)0);
void tick_thread()
pthread_create(&pthread_id_tick , NULL, my_tick, NULL);
int main(int argc, char *argv[])
lv_wayland_init();
lv_wayland_create_window(240, 240, "poweroff", NULL);
my_tick_thread();
while (1)
my_lvgl_lock();
lv_task_handler();
my_lvgl_unlock();
usleep(HANDLE_THREAD_SLEEP_TIME); // HANDLE_THREAD_SLEEP_TIME = 1000
return 0;
/* Test code */
static void loading_set_angle(void *loading_img, int32_t rotate_angle)
lv_img_set_angle((lv_obj_t *)loading_img, rotate_angle);
void gen_loading_animation(lv_obj_t *obj, uint expect_delay, uint expect_duration)
lv_anim_t animation;
if (!obj)
return;
if (expect_delay > 0)
lv_anim_set_delay(animation, expect_delay * ANIM_1_SEC / 1000);
lv_anim_set_delay(animation, ANIM_1_SEC);
if (expect_duration > 0)
lv_anim_set_time(animation, expect_duration * ANIM_1_SEC / 1000);
lv_anim_set_time(animation, ANIM_1_SEC);
lv_anim_init(&animation);
lv_anim_set_var(&animation, obj);
lv_anim_set_values(&animation, 0, 3600);
lv_anim_speed_to_time(1, 0, 3600);
lv_anim_set_repeat_count(&animation, LV_ANIM_REPEAT_INFINITE);
lv_anim_set_exec_cb(&animation, loading_set_angle);
lv_anim_start(&animation);
void test_loading_anim()
lv_obj_t *scr = lv_scr_act();
lv_obj_t *img = lv_img_create(scr);
lv_obj_set_size(scr, 240, 240);
lv_obj_clear_flag(scr, LV_OBJ_FLAG_SCROLLABLE);
// new_icon_loading is a icon of the kind loading circles
lv_obj_set_size(img, new_icon_loading.header.w, new_icon_loading.header.h);
lv_obj_center(img);
lv_img_set_src(img, &new_icon_loading);
gen_loading_animation(img, 2000, 5000);
