Before posting
masterbranch.- Be sure you have checked the relevant part of the documentation.
hi, I need to show dropdown list options with some chinese charactor, so I add my font to the button style by lv_obj_add_style(ddlist, &style, LV_PART_MAIN), but when I open the dropdown list, the options in the list is not fully display. So I read the docs again and try to add the list style in the LV_EVENT_VALUE_CHANGED, but it still doesn’t work. I debug the code shown below, I found while it open the dropdown list, it can’t run into the if condition, only when I clicked one option it can. Also, the list I get is always NULL.
V 8.0.1
lv_style_t g_generalDropDownlist_Bg;
lv_style_t g_generalDropDownlist_List;
static void dropdownlist_event_cb(lv_event_t* e)
if (code == LV_EVENT_VALUE_CHANGED)
lv_obj_t* list = lv_dropdown_get_list(obj);
if (list != NULL)
lv_obj_add_style(list, &g_generalDropDownlist_List, LV_PART_MAIN);
int main()
lv_style_init(&g_generalDropDownlist_Bg);
lv_style_set_radius(&g_generalDropDownlist_Bg, 0);
lv_style_set_text_font(&g_generalDropDownlist_Bg, &msyh_12);
lv_style_init(&g_generalDropDownlist_List);
lv_style_set_text_font(&g_generalDropDownlist_List, &msyh_12);
s_limitObj.ddlist = lv_dropdown_create(parent);
lv_dropdown_set_symbol(s_limitObj.ddlist, NULL);
lv_obj_add_style(s_limitObj.ddlist, &g_generalDropDownlist_Bg, LV_PART_MAIN);
lv_dropdown_set_options(s_limitObj.ddlist, "参数1\n参数2\n参数3");
lv_obj_set_width(s_limitObj.ddlist, 120);
lv_obj_add_event_cb(s_limitObj.ddlist, dropdownlist_event_cb, LV_EVENT_VALUE_CHANGED, NULL);
lv_obj_align_to(s_limitObj.ddlist, LimitParamGroup,
LV_ALIGN_OUT_RIGHT_MID, 16, 0);
