Before posting
masterbranch.- Be sure you have checked the relevant part of the documentation.
Windows10 by CodeBlocks
Version 8.0.0
I wish to set roller’s options 256 options.
But it can set only 62 options maximum.
I tried set roller’s option to 62 options it can display well.
However when set options to 63 options it can’t display.
static void event_handler(lv_event_t * e)
if(code == LV_EVENT_VALUE_CHANGED) {
char buf[32];
lv_roller_get_selected_str(obj, buf, sizeof(buf));
LV_LOG_USER("Selected month: %s\n", buf);
// "V1\nV2\nV3\nV4\nV5\nV6\nV7\nV8\nV9\nV10\nV11\nV12\nV13\nV14\nV15\nV16\nV17\nV18\nV19\nV20\nV21\nV22\nV23\nV24\nV25\nV26\nV27\nV28\nV29\nV30\nV31\nV32\nV33\nV34\nV35\nV36\nV37\nV38\nV39\nV40\nV41\nV42\nV43\nV44\nV45\nV46\nV47\nV48\nV49\nV50\nV51\nV52\nV53\nV54\nV55\nV56\nV57\nV58\nV59\nV60\nV61\nV62\nV63\nV64\nV65\nV66\nV67\nV68\nV69\nV70\nV71\nV72\nV73\nV74\nV75\nV76\nV77\nV78\nV79\nV80\nV81\nV82\nV83\nV84\nV85\nV86\nV87\nV88\nV89\nV90\nV91\nV92\nV93\nV94\nV95\nV96\nV97\nV98\nV99\nV100\nV101\nV102\nV103\nV104\nV105\nV106\nV107\nV108\nV109\nV110\nV111\nV112\nV113\nV114\nV115\nV116\nV117\nV118\nV119\nV120\nV121\nV122\nV123\nV124\nV125\nV126\nV127\nV128\nV129\nV130\nV131\nV132\nV133\nV134\nV135\nV136\nV137\nV138\nV139\nV140\nV141\nV142\nV143\nV144\nV145\nV146\nV147\nV148\nV149\nV150\nV151\nV152\nV153\nV154\nV155\nV156\nV157\nV158\nV159\nV160\nV161\nV162\nV163\nV164\nV165\nV166\nV167\nV168\nV169\nV170\nV171\nV172\nV173\nV174\nV175\nV176\nV177\nV178\nV179\nV180\nV181\nV182\nV183\nV184\nV185\nV186\nV187\nV188\nV189\nV190\nV191\nV192\nV193\nV194\nV195\nV196\nV197\nV198\nV199\nV200\nV201\nV202\nV203\nV204\nV205\nV206\nV207\nV208\nV209\nV210\nV211\nV212\nV213\nV214\nV215\nV216\nV217\nV218\nV219\nV220\nV221\nV222\nV223\nV224\nV225\nV226\nV227\nV228\nV229\nV230\nV231\nV232\nV233\nV234\nV235\nV236\nV237\nV238\nV239\nV240\nV241\nV242\nV243\nV244\nV245\nV246\nV247\nV248\nV249\nV250\nV251\nV252\nV253\nV254\nV255\nV256",
* An infinite roller with the name of the months
void lv_example_roller_1(void)
lv_obj_t *roller1 = lv_roller_create(lv_scr_act());
lv_roller_set_options(roller1,
"V1\nV2\nV3\nV4\nV5\nV6\nV7\nV8\nV9\nV10\nV11\nV12\nV13\nV14\nV15\nV16\nV17\nV18\nV19\nV20\nV21\nV22\nV23\nV24\nV25\nV26\nV27\nV28\nV29\nV30\nV31\nV32\nV33\nV34\nV35\nV36\nV37\nV38\nV39\nV40\nV41\nV42\nV43\nV44\nV45\nV46\nV47\nV48\nV49\nV50\nV51\nV52\nV53\nV54\nV55\nV56\nV57\nV58\nV59\nV60\nV61\nV62nV63",
LV_ROLLER_MODE_INFINITE);
lv_roller_set_visible_row_count(roller1, 4);
lv_obj_center(roller1);
lv_obj_add_event_cb(roller1, event_handler, LV_EVENT_ALL, NULL);
The roller 62 options can display.
When tested by 63 options , it can’t display anything.
