Before posting
masterbranch.- Be sure you have checked the relevant part of the documentation.
- how to set cells height in a table? It seems different from V6.0.2, I read the docs and try to add the padding style to the table, it seems not work.
- By the way, in V6.0.2, there is a declare
LV_TABLE_COL_MAXinlv_conf.h, in V8.0.1, is still has this declare and the limit of table column num?
8.0.1
static void ta_event_cb(lv_event_t * e)
lv_obj_t * ta = lv_event_get_target(e);
if(code == LV_EVENT_CLICKED || code == LV_EVENT_FOCUSED) {
/*Focus on the clicked text area*/
if(g_keyboard != NULL)
lv_obj_clear_flag(g_keyboard, LV_OBJ_FLAG_HIDDEN);
lv_keyboard_set_textarea(g_keyboard, ta);
else if(code == LV_EVENT_READY) {
LV_LOG_USER("Ready, current text: %s", lv_textarea_get_text(ta));
static void KeyboardEventCB(lv_event_t* event)
// lv_keyboard_def_event_cb(event);
// lv_obj_t* ta_of_kb = lv_keyboard_get_textarea(g_keyboard);
if(code == LV_EVENT_CANCEL)
// lv_textarea_t * ta = (lv_textarea_t *)ta_of_kb;
// ta->cursor.show = 0;
lv_obj_add_flag(g_keyboard, LV_OBJ_FLAG_HIDDEN);
void CreateKeyboard(lv_obj_t* parent, lv_coord_t w, lv_coord_t h)
g_keyboard = lv_keyboard_create(parent);
lv_obj_set_size(g_keyboard, w, h);
lv_obj_align_to(g_keyboard, parent, LV_ALIGN_BOTTOM_RIGHT, 0, 0);
// lv_obj_add_event_cb(g_keyboard, KeyboardEventCB, LV_EVENT_CANCEL, NULL);
// lv_obj_add_flag(g_keyboard, LV_OBJ_FLAG_HIDDEN);
int main()
CreateKeyboard(lv_scr_act(), 940, 150);
lv_obj_t * text_ta = lv_textarea_create(lv_scr_act());
lv_textarea_set_one_line(text_ta, true);
lv_textarea_set_password_mode(text_ta, false);
lv_obj_set_width(text_ta, lv_pct(40));
lv_obj_add_event_cb(text_ta, ta_event_cb, LV_EVENT_ALL, NULL);
lv_obj_align_to(text_ta, NULL, LV_ALIGN_TOP_LEFT, 0, 60);
lv_obj_t * text_ta1 = lv_textarea_create(lv_scr_act());
lv_textarea_set_one_line(text_ta1, true);
lv_textarea_set_password_mode(text_ta1, false);
lv_obj_set_width(text_ta1, lv_pct(40));
lv_obj_add_event_cb(text_ta1, ta_event_cb, LV_EVENT_ALL, NULL);
lv_obj_align_to(text_ta1, NULL, LV_ALIGN_TOP_RIGHT, 0, 60);
