How to make the major ticks center the bars of the chart ?
Before posting
Hi, I draw a bar chart that is 255*120. But I found that the major ticks don`t center the bars of the chart.
V8.2
I want to make the major ticks center the bars of the chart.
I tried to decrese the numbers of the bars in the bar chart, and found that when the number of the bars is small, the major ticks center the bars of the chart.
So is there any other way?
static lv_coord_t A_phase_data[] = {32,35,38,41,44,47,49,52,54,56,58,60,61,62,63,63};
lv_obj_t *chart = chart = lv_chart_create(harmonic_wave_page);
lv_obj_set_size(chart, 255, 120);
lv_obj_align_to(chart, esc_btn, LV_ALIGN_OUT_TOP_LEFT, 25, -25);
lv_obj_set_style_pad_column(chart, 0, LV_PART_MAIN);
lv_chart_set_type(chart, LV_CHART_TYPE_BAR);
lv_chart_set_point_count(chart, 16);
static lv_chart_series_t *A_phase_ser = lv_chart_add_series(chart, lv_palette_main(LV_PALETTE_GREEN), LV_CHART_AXIS_PRIMARY_Y);
lv_chart_set_ext_y_array(chart, A_phase_ser, A_phase_data);
lv_chart_refresh(chart);
lv_chart_set_axis_tick(chart, LV_CHART_AXIS_PRIMARY_X, 5, 0, 16, 1, true, 50);
@kisvegabor
I’ve pushed a fix to master.
