How can I make the color of the graph translucent? I’m displaying a graph as a BAR and I want them to be semi-transparent. Is it possible to do this?
Before posting
Pic32MZ
8.3
PanelABSCAN.AScan = lv_chart_create(PanelABSCAN.Panel);
lv_obj_set_width(PanelABSCAN.AScan, 272);
lv_obj_set_height(PanelABSCAN.AScan, 140);
if(Config.Screen.Fill) {lv_chart_set_type(PanelABSCAN.AScan, LV_CHART_TYPE_BAR);}
else {lv_chart_set_type(PanelABSCAN.AScan, LV_CHART_TYPE_LINE);}
lv_chart_set_range(PanelABSCAN.AScan, LV_CHART_AXIS_PRIMARY_Y, -2047, 2047);
lv_chart_set_div_line_count(PanelABSCAN.AScan, 11, 11);
lv_chart_set_axis_tick(PanelABSCAN.AScan, LV_CHART_AXIS_PRIMARY_X, 0, 0, 10, 2, true, 50);
lv_chart_set_axis_tick(PanelABSCAN.AScan, LV_CHART_AXIS_PRIMARY_Y, 0, 0, 5, 0, false, 50);
lv_chart_set_axis_tick(PanelABSCAN.AScan, LV_CHART_AXIS_SECONDARY_Y, 0, 0, 5, 2, false, 25);
lv_obj_set_style_border_opa(PanelABSCAN.AScan, 255, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_border_width(PanelABSCAN.AScan, 1, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_radius(PanelABSCAN.AScan, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_pad_left(PanelABSCAN.AScan, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_pad_right(PanelABSCAN.AScan, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_pad_top(PanelABSCAN.AScan, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_pad_bottom(PanelABSCAN.AScan, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_size(PanelABSCAN.AScan, 0, LV_PART_INDICATOR | LV_STATE_DEFAULT); // выключить точки
lv_obj_set_style_text_align(PanelABSCAN.AScan, LV_TEXT_ALIGN_CENTER, LV_PART_TICKS | LV_STATE_DEFAULT);
## Screenshot and/or video
