Before posting
I want draw a button and a list of this buttons using the same style. how can I achieve this :
stm32f103
LVGL 8.3
I had tried to plot button with lv_style_set_border_side(&BT_style, LV_BORDER_SIDE_TOP | LV_BORDER_SIDE_LEFT);
but the four borders’ color is same.
void setup_scr_screen(lv_ui* ui) {
if (BT_style.prop_cnt > 1)
lv_style_reset(&BT_style);
lv_style_init(&BT_style);
/*Set a background color and a radius*/
lv_style_set_radius(&BT_style, 1);
lv_style_set_bg_opa(&BT_style, LV_OPA_COVER);
lv_style_set_bg_color(&BT_style, lv_color_make(200, 0, 0));
lv_style_set_border_color(&BT_style, lv_color_make(200, 200, 10));
lv_style_set_border_width(&BT_style, 3);
lv_style_set_border_opa(&BT_style, LV_OPA_50);
lv_style_set_outline_opa(&BT_style, LV_OPA_TRANSP);
lv_style_set_outline_width(&BT_style, 0);
lv_style_set_outline_color(&BT_style, lv_color_make(200, 200, 200));
/* lv_style_set_height(&BT_style, 50);
lv_style_set_width(&BT_style, 100);*/
ui->screen_btn = lv_btn_create(ui->screen);
lv_obj_remove_style_all(ui->screen_btn );
lv_obj_add_flag(ui->screen_btn , LV_OBJ_FLAG_CHECKABLE);
lv_obj_add_style(ui->screen_btn , &BT_style, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_add_event_cb(ui->screen,button_draw_event_cb,LV_EVENT_DRAW_PART_BEGIN,NULL);
static void button_draw_event_cb(lv_event_t* e)
lv_obj_t* ta = lv_event_get_target(e);
lv_obj_t* kb = lv_event_get_user_data(e);
if (code == LV_EVENT_DRAW_PART_BEGIN)
lv_style_set_border_color(&BT_style, lv_color_make(0, 200, 0));
if (code == LV_EVENT_DRAW_PART_END)
