How to make arithmetic operations with float or double
Before posting
Adruino Giga R1 with giga display shield on arduino ide 2.3.6
9.2.2
I want to set (with embedded keyboard) a float or double value on a text label, then multiplie them, and print the result on another label.
All i want above, works perfect with integer type, but never with float or double. I extract the string with “lv_label_get_text” then convert it with “atoi” fonction (and made an operation).
I try fonction “atof” “strtod” “strtof” and it always print a big value (10 or 12 digits before dot when i expect 2).
I change the defaut code compiler by -std=gnuC99 : Works a little better but not as expected.
I don’t expect you to debug my code problem. I’m pretty sur that’s simple and i miss something basic.
So my question is : Show me an exemple of code (2 or 3 lines) of what you do for extract a value (float) from a label.
I search an exemple since one month but never find it.
Thanks
static lv_obj_t* label1;
static lv_obj_t* label2;
static lv_obj_t* label_result;
void btn_event_cb(lv_event_t* e)
if (code == LV_EVENT_CLICKED) {
    const char* str1 = lv_label_get_text(label1);
    const char* str2 = lv_label_get_text(label2);
    float num1 = atof(str1);
    float num2 = atof(str2);
    float result = num1 * num2;
    char buf[32];
    snprintf(buf, sizeof(buf), "%.2f", result);
    lv_label_set_text(label_result, buf);
void create_ui(void)
lv_obj_t* cont = lv_obj_create(lv_screen_active());
lv_obj_set_size(cont, 200, 200);
lv_obj_center(cont);
// label1
label1 = lv_label_create(cont);
lv_label_set_text(label1, "4.14");
lv_obj_align(label1, LV_ALIGN_TOP_LEFT, 10, 20);
// label2
label2 = lv_label_create(cont);
lv_label_set_text(label2, "2.2");
lv_obj_align(label2, LV_ALIGN_TOP_RIGHT, -10, 20);
// btn
lv_obj_t* btn = lv_btn_create(cont);
lv_obj_align(btn, LV_ALIGN_CENTER, 0, 0);
lv_obj_add_event_cb(btn, btn_event_cb, LV_EVENT_CLICKED, NULL);
// btn_label
lv_obj_t* btn_label = lv_label_create(btn);
lv_label_set_text(btn_label, "Multiply");
lv_obj_center(btn_label);
// result_label
label_result = lv_label_create(cont);
lv_label_set_text(label_result, "0.00");
lv_obj_align(label_result, LV_ALIGN_BOTTOM_MID, 0, -20);
you may need to enable LV_USE_FLOAT in lv_conf.h
Thanks for your replie.
I try this and it didn’t work. For example, when i multiplie 5.8 x 12.1 the printed result is 12 or 14 digits and always terminated by .00
things i try :
-I obviously enable LV_USE_FLOAT in lv_conf9.h
-Change float type by double type (and of course changing the function).
-Modifiy
#define LV_USE_STDLIB_SPRINTF    LV_STDLIB_BUILTIN
to
#define LV_USE_STDLIB_SPRINTF     LV_STDLIB_CLIB
or
#define LV_USE_STDLIB_SPRINTF     LV_STDLIB_CUSTOM
-Add in lv_conf.h
#define LV_SPRINTF_CUSTOM 1
#if LV_SPRINTF_CUSTOM
    #define LV_SPRINTF_INCLUDE <stdio.h>
    #define lv_snprintf  snprintf
    #define lv_vsnprintf vsnprintf
#else   /*LV_SPRINTF_CUSTOM*/
    #define LV_SPRINTF_USE_FLOAT 1
#endif  /*LV_SPRINTF_CUSTOM*/
#define LV_USE_USER_DATA 1
-Change <stdio.h> by <stdlib.h> : no compilation
-Add “#include <stdlib.h>” in the .ino file : Same problem.
-Change “atof()” by “strtof()” : arduino stop working.
I think i miss a parameter in some configuration file but where ? Is possibly a conflict with parameter files between arduino_H7_video library and lvgl library ?
So.
After many hours to make some tests, I can say :
atof() function DIDN’T work on my board.
I use instead the sscanf function.
here the code work as i want :
include "ui.h"
void calcul(lv_event_t* e) {
  const char* str1 = lv_label_get_text(ui_LabelVal1);
  const char* str2 = lv_label_get_text(ui_LabelVal2);
  float num1, num2;
  sscanf(str1, "%f", &num1);
  sscanf(str1, "%f", &num2);
  lv_label_set_text_fmt(ui_LabelResult, "%.3f", result);
Problem solved :slight_smile:
PS :
#include <stdio.h>
at top of your file
