I want to make a curved progress bar. Which one can I apply?
Before posting
Get familiar with Markdown to format and structure your post
Be sure to update lvgl from the latest version from the master branch.
Be sure you have checked the relevant part of the documentation.
If applicable use the Simulator to eliminate hardware related issues.
What LVGL version are you using? Ver 8.0
What do you want to achieve? I want to do it like the video below. But the code in this video is not efficient.
Bar: Unbent
line: cannot be parent
Please advise.
If possible, add screenshots and/or videos about the current state. video
Do you need to generate the curved path runtime? If not, you can use ARGB image on which the line to fill is a hole (transparent) and put a red object below it and increase the size of that object as the process progresses.
You can also draw the path to an LV_IMG_CF_ALPHA_8BIT canvas and use it as mask on similarly to the ARGB image before.
Or the path can be created from many short lines and you can change the colors of the line segments as the time passes (I can show an example for it.)
@kisvegabor do you have some example? I search all website can not find any lv_objmask example for v8.3, in the document only a few word mention mask. And in the internet the example:
4 void lv_ex_objmask_1(void)
5 {
6
7 /Set a very visible color for the screen to clearly see what happens/
8 lv_obj_set_style_local_bg_color(lv_scr_act(), LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, lv_color_hex3(0xf33));
9
10 lv_obj_t * om = lv_objmask_create(lv_scr_act(), NULL);
11 lv_obj_set_size(om, 200, 200);
12 lv_obj_align(om, NULL, LV_ALIGN_CENTER, 0, 0);
13 lv_obj_t * label = lv_label_create(om, NULL);
14 lv_label_set_long_mode(label, LV_LABEL_LONG_BREAK);
15 lv_label_set_align(label, LV_LABEL_ALIGN_CENTER);
BUT in v8.3 does not have lv_objmask_create function.
* DEFINES
const lv_coord_t mask_width = 792;
const lv_coord_t mask_height = 202;
* TYPEDEFS
* STATIC PROTOTYPES
static void hal_init(void);
static int tick_thread(void *data);
* STATIC VARIABLES
lv_ui guider_ui;
* MACROS
/* Create the mask of a text by drawing it to a canvas*/
lv_color_t mask_map[LV_CANVAS_BUF_SIZE_TRUE_COLOR_ALPHA(792,202)];
static void mask_event_cb(lv_event_t * e);
* GLOBAL FUNCTIONS
int APIENTRY WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance, LPSTR szCmdLine, int nCmdShow)
int i;
/*Initialize LittlevGL*/
/*Initialize the HAL for LittlevGL*/
lv_win32_init(hInstance, SW_SHOWNORMAL, 800, 480, NULL);
/*Output prompt information to the console, you can also use printf() to print directly*/
LV_LOG_USER("LVGL initialization completed!");
/*Run the demo*/
//lv_demo_widgets();
setup_ui(&guider_ui);
lv_obj_add_event_cb(guider_ui.screen_img_1, mask_event_cb, LV_EVENT_ALL, guider_ui.screen_img_1);
while(!lv_win32_quit_signal) {
/* Periodically call the lv_task handler.
* It could be done in a timer interrupt or an OS task too.*/
lv_task_handler();
usleep(10000); /*Just to let the system breath*/
return 0;
static void mask_event_cb(lv_event_t * e) {
static lv_draw_mask_map_param_t m;
static int16_t mask_id;
if (code == LV_EVENT_COVER_CHECK) {
lv_event_set_cover_res(e, LV_COVER_RES_MASKED);
else if (code == LV_EVENT_DRAW_MAIN_BEGIN) {
/*Create a "8 bit alpha" canvas and clear it*/
lv_obj_t* canvas = lv_canvas_create(lv_scr_act());
lv_canvas_set_buffer(canvas, mask_map, mask_width, mask_height, LV_IMG_CF_TRUE_COLOR_ALPHA);
lv_canvas_fill_bg(canvas, lv_color_black(), LV_OPA_TRANSP);
/*Draw a label to the canvas. The result "image" will be used as mask*/
lv_draw_rect_dsc_t rect_dsc;
lv_draw_rect_dsc_init(&rect_dsc);
rect_dsc.radius = 0;
rect_dsc.bg_opa = LV_OPA_COVER;
rect_dsc.bg_color = lv_color_white();
rect_dsc.bg_grad.dir = LV_GRAD_DIR_NONE;
rect_dsc.border_width = 0;
lv_canvas_draw_rect(canvas, 0, 0, 150, 100, &rect_dsc);
/*The mask is reads the canvas is not required anymore*/
lv_obj_del(canvas);
/* Create an object from where the text will be masked out.
* Now it's a rectangle with a gradient but it could be an image too*/
lv_draw_mask_map_init(&m, &obj->coords, mask_map);
mask_id = lv_draw_mask_add(&m, NULL);
else if (code == LV_EVENT_DRAW_MAIN_END) {
lv_draw_mask_free_param(&m);
lv_draw_mask_remove_id(mask_id);
I want to use mask to make the animation. I use codeblocks simulator. And I found I draw a rectangle on canvas also like windows-shades. And another strange thing, the image width is 792, but if I set the rectangle width is 200, the mask will full of the image.
I check the code, lv_draw_mask_map_init(lv_draw_mask_map_param_t * param, const lv_area_t * coords, const lv_opa_t * map)
the map point is lv_opa_t, but my buffer is lv_color_t.
Is this problem? @kisvegabor
