Before posting
Get familiar with Markdown to format and structure your post
Be sure to update lvgl from the latest version from the master branch.
Be sure you have checked the FAQ and read the relevant part of the documentation.
If applicable use the Simulator to eliminate hardware related issues.
V8
Thanks for reply,
I think it is difficult to rotate a picture with two positions at the same time. One position is the center of the background , the other one is the center of itself. And the center of itself is always moving.
Great Idea, are you using SquareLine Studio or LVGL and Ardunio.
Here is our, Mike Morrow and myself, attempt to make a GPS using LilyGO T4 S3 AMOLED board/display. We are using SLS and Mike’s Ardunio ino code. It’s a slow learning process.
