Before posting
I have studied LVGL for about three years, I need to make a scroll panel, and when scroll panel’s child locate in the center, panel’s child need to be enlarged.
I use LV_EVENT_SCROLL, when panel recieved this event, its use lv_img_set_zoom to make child located canter larger.
but when I use lv_img_set_zoom, the fps(frame rate) is lower, between 9~15.
So, does Lvgl has any function to solve this question?
by the way, chage img’s angle will make fps(frame rate) lower too;
ESP
8.3.3
have better fps when I use lv_img_set_zoom.
the code is:
when i scroll panel, the fps will be low.
I have use larger draw buffer, but it’s not useful
draw buffer size is more than 1/2 of screen
static void scroll_event(lv_event_t e)
lv_obj_t* target = lv_event_get_targetr(e);
if(event_code == LV_EVENT_SCROLL{
get_target_child_locate();
if(is_child_in_center()){
lv_set_img_zoom(child, 400);
