Before posting
When I Slide a little on the page of tabview it can’t return to the original position.I try many ways can,t soulve this problem
visual studio
Deal some problems of plug-ins in lvgl
set the position of tabview’s children as the absolute position
```static lv_style_t tabviewStyle;
tabview = lv_tabview_create(lv_scr_act(), NULL);
lv_obj_set_size(tabview, LV_HOR_RES, LV_VER_RES);
lv_tabview_set_btns_pos(tabview, LV_TABVIEW_TAB_POS_NONE);
lv_obj_add_style(tabview, LV_OBJ_PART_MAIN, CommonGetDefaultBgStyle());
lv_obj_set_pos(tabview, 0, 0);
tab0 = lv_tabview_add_tab(tabview, "Tab0");
tab1 = lv_tabview_add_tab(tabview, "Tab1");
lv_page_set_scrlbar_mode(tab0, LV_SCRLBAR_MODE_OFF);
lv_page_set_scrlbar_mode(tab1, LV_SCRLBAR_MODE_OFF);
lv_obj_set_event_cb(tabview, tabview_event_handler);
lv_tabview_set_tab_act(tabview, 1, LV_ANIM_OFF);
static lv_style_t rollerbgstyle, rollerselstyle;
lv_style_reset(&rollerselstyle);
lv_style_init(&rollerselstyle);
lv_style_set_bg_color(&rollerselstyle, LV_STATE_DEFAULT, LV_COLOR_BLACK);
lv_style_set_radius(&rollerselstyle, LV_STATE_DEFAULT, 1);
lv_style_set_bg_opa(&rollerselstyle, LV_STATE_DEFAULT, LV_OPA_0);
lv_style_set_text_color(&rollerselstyle, LV_STATE_DEFAULT, LV_COLOR_MAKE(0x00, 0xd8, 0xff));
/*roller backgroud style set*/
lv_style_reset(&rollerbgstyle);
lv_style_init(&rollerbgstyle);
lv_style_set_bg_color(&rollerbgstyle, LV_STATE_DEFAULT, LV_COLOR_BLACK);
lv_style_set_bg_opa(&rollerbgstyle, LV_STATE_DEFAULT, LV_OPA_100);
lv_style_set_radius(&rollerbgstyle, LV_STATE_DEFAULT, 12);
lv_style_set_text_font(&rollerbgstyle, LV_STATE_DEFAULT, &Alibaba_PuHuiTi_M_Alarm30px);
lv_style_set_text_opa(&rollerbgstyle, LV_STATE_DEFAULT, LV_OPA_100);
lv_style_set_text_line_space(&rollerbgstyle, LV_STATE_DEFAULT, 42);
lv_style_set_text_color(&rollerbgstyle, LV_STATE_DEFAULT, LV_COLOR_GRAY);
addtimeroller[HOUR] = lv_roller_create(tab1, NULL);
lv_obj_add_style(edittimeroller[HOUR], LV_ROLLER_PART_BG, &rollerbgstyle);
lv_obj_add_style(edittimeroller[HOUR], LV_ROLLER_PART_SELECTED, &rollerselstyle);
lv_roller_set_options(addtimeroller[HOUR], HourBuf, LV_ROLLER_MODE_INIFINITE);
lv_roller_set_visible_row_count(addtimeroller[HOUR], 3);
lv_obj_set_event_cb(addtimeroller[HOUR], addalarmselect_event_handler);
lv_obj_set_pos(addtimeroller[HOUR], 76, 68);
## Screenshot and/or video
