Before posting
Hello, I have two apps App1 and App2 which use lvgl to create UI . I want to run App1, and then close its UI and exit lvgl of App1 when some event triggers , and then start App2 by App1.
At first, i used the framebuffer driver as display, and it works well.
Due to project requirements, i replaced the framebuffer driver with DRM driver and i met some errors when App2 starts.
It prints the errors:
error:drmModeAtomicCommit failed: Permission denied
error: Flush fail
Does the process App1 still hold DRM resources when drm_exit() called, resulting in another process App2 not being able to obtain DRM resources?
I tried to repeatedly initialize lvgl and DRM, exit lvgl and DRM in the same process App1, and there was no problem.
How to completely release DRM resources for a process?
armv8
v7
void drm_init(void)
int ret;
ret = drm_setup(DRM_FOURCC);
if (ret) {
close(drm_dev.fd);
drm_dev.fd = -1;
return;
ret = drm_setup_buffers();
if (ret) {
err("DRM buffer allocation failed");
close(drm_dev.fd);
drm_dev.fd = -1;
return;
info("DRM subsystem and buffer mapped successfully");
void drm_exit(void)
close(drm_dev.fd);
drm_dev.fd = -1;
