Before posting
Using Renesas RA4M2
It’s the latest version.
I want to display buffer or image using ssd1327.
but i can not find "lv_disp_drv_t "
This is my code
void hal_entry(void)
/* TODO: add your own code here */
fsp_err_t err = R_SCI_I2C_Open(&g_i2c9_ctrl, &g_i2c9_cfg);
if(err == FSP_SUCCESS){
OLED_Init();
// To create a display buffer
lv_disp_t * disp = lv_disp_create(DISPLAY_WIDTH, DISPLAY_HEIGHT);
lv_disp_set_flush_cb(disp, dummy_flush_cb);
lv_disp_flush_ready(disp);
// Draw bufffers
lv_disp_set_draw_buffers(disp, buf, NULL, sizeof(buf), LV_DISP_RENDER_MODE_DIRECT);
// Display driver
while(1)
lv_task_handler();
lv_tick_inc(5);
R_BSP_SoftwareDelay(5, BSP_DELAY_UNITS_MILLISECONDS);
“lv_conf.h”, “lvgl folder” path is right??
