Before posting
As shown in the video, I click the button to open the menu interface, which is made up of a PNG image as the full-screen background and several other small PNG images as the buttons. Yes, I have added libraries to support opening PNG images, but when I click the button to enter the menu, the whole UI displays very slowly, which takes about a second to display.
Also, if I remove the PNG image from the background, it will be fast when I click the menu button!
So I want to know how to display a full screen PNG image quickly, or what is the reason for the slow display?
7.4.2
Quickly displays a full-screen PNG image
At present do not know how to solve
video.zip (771.8 KB)
