Before posting
masterbranch.- Be sure you have checked the relevant part of the documentation.
In v8, it seems add lots of animotion effect to widgets. Such as pressing a checkbox, a button , etc. It seems worked smoothly in the docs examples, but when I run it in my device(CPU ARM335X), it seems not so smoothly than the docs example. So is there has some APIs or switches to speed up animation effect, or disable the widget action animotion?
arm335x
8.0.1
