How to create a screen backstage
Before posting
  • Be sure you have checked the relevant part of the documentation. We will not respond in detail to posts where you haven’t read the relevant documentation.
windows 7 system and with the visual studio 2019 professional
v7.1
Create a screen backstage not the lv_scr_act().
I create the screen named “incoming” which base on lv_scr_act(),but at the same time I want to create a screen named “message” backstage instead of cover the “incoming” screen.So when I delete the “incoming” screen,the “message” screen will show, but I don’t know how to do it.
You can create two lv_objs on the incoming screen. The first one (in the background) can be used as “message”. The second can be used as “incoming”. That way you can create objects in the background without them being visible.
Thank you very much I try it and it success,The first one has it’s own address and the second is base on lv_scr_act().
If one day,the LVGL library function is perfect,is it charge ?
Sorry; I didn’t understand your question. Maybe there’s a translation issue?
I am sorry,My English is so pool.Does the LVGL tool will not free?
As far as I know there are no plans to make LVGL itself a paid product (though extra tools and services could be commercial).
Exactly as @embeddedt said. We are planning to keep LVGL free under MIT license as now but we do have paid services and we are developing paid tools.
