How to control the degree of display of the image through mask
Before posting
  • Simulator in Ubuntu 20.04
  • 8.3.3
  • How to control the degree of display of rpm_normal.png picture through mask like target.png
I am currently using the AWTK widget library and need to migrate to LVGL 8.3.3. However, I am unable to achieve the desired image rotation, and I have not found a suitable API interface for this
It’s just an arch widget in LVGL. No need to use mask here:
arc
    lv_obj_t * arc = lv_arc_create(lv_scr_act());
    lv_obj_set_size(arc, 150, 150);
    lv_arc_set_rotation(arc, 135);
    lv_arc_set_bg_angles(arc, 0, 270);
    lv_arc_set_value(arc, 10);
    lv_obj_center(arc);
    lv_obj_set_style_arc_width(arc, 30, LV_PART_MAIN);
    lv_obj_set_style_arc_rounded(arc, false, LV_PART_MAIN);
    lv_obj_set_style_arc_opa(arc, LV_OPA_50, LV_PART_MAIN);
    lv_obj_set_style_arc_width(arc, 30, LV_PART_INDICATOR);
    lv_obj_set_style_arc_rounded(arc, false, LV_PART_INDICATOR);
    lv_obj_set_style_bg_opa(arc, 0, LV_PART_KNOB);
