How to change the roller selected text font size
Before posting
  • Be sure you have checked the relevant part of the documentation. We will not respond in detail to posts where you haven’t read the relevant documentation.
visual studio PC monitor
Change the roller widget selected font size.
I set the roller’s bg_style and sel_style and fond the seleced fond didn’t work
    /*roller backgroud style set*/
	static lv_style_t  rollerbg_style;
	lv_style_copy(&rollerbg_style,&lv_style_scr);
	rollerbg_style.body.main_color = LV_COLOR_BLACK;
	rollerbg_style.body.grad_color = LV_COLOR_BLACK;
	rollerbg_style.body.opa = LV_OPA_100;
	rollerbg_style.body.radius = 12;
	rollerbg_style.text.font = &Alibaba_PuHuiTi_M_Alarm30px;
	rollerbg_style.text.opa = LV_OPA_100;
	rollerbg_style.text.line_space = 42;
	rollerbg_style.text.color = LV_COLOR_GRAY;
	/*roller seltext style set */
	static lv_style_t rollersel_style;
	lv_style_copy(&rollersel_style, &lv_style_transp);
	rollersel_style.body.main_color = LV_COLOR_BLACK;
	rollersel_style.body.grad_color = LV_COLOR_BLACK;
	rollersel_style.body.radius= 1;
	rollersel_style.body.opa = LV_OPA_0;/*completely opa*/
	rollersel_style.text.font = &Alibaba_PuHuiTi_M_Alarm45px;
	rollersel_style.line.width = 10;
	rollersel_style.text.opa = LV_OPA_100;
	rollersel_style.text.line_space = 61;
	rollersel_style.text.color = LV_COLOR_MAKE(0x00, 0xd8, 0xff);
	const char *HourBuf = "00\n01\n02\n03\n04\n05\n06\n07\n08\n09\n10\n11\n12\n13\n14\n15\n16\n17\n18\n19\n20\n21\n22\n23";
	lv_obj_t * hour_roller = lv_roller_create(tabalarm1, NULL);
	lv_roller_set_style(hour_roller, LV_ROLLER_STYLE_BG,&rollerbg_style);
	lv_roller_set_style(hour_roller, LV_ROLLER_STYLE_SEL, &rollersel_style);
	lv_roller_set_options(hour_roller, HourBuf, LV_ROLLER_MODE_INIFINITE);
	lv_roller_set_visible_row_count(hour_roller, 3);
	lv_obj_set_event_cb(hour_roller, hue_select_event_cb);
	lv_obj_set_pos(hour_roller,67,68);
	const char *MinuteBuf = "00\n01\n02\n03\n04\n05\n06\n07\n08\n09\n10\n11\n12\n13\n14\n15\n16\n17\n18\n19\n20\n21\n22\n23\n24\n25\n26\n27\n28\n29\n30"
		                   "\n31\n32\n33\n34\n35\n36\n37\n38\n39\n40\n41\n42\n43\n44\n45\n46\n47\n48\n49\n50\n51\n52\n53\n54\n55\n56\n57\n58\n59";
	lv_obj_t * minute_roller = lv_roller_create(tabalarm1, NULL);
	lv_roller_set_style(minute_roller, LV_ROLLER_STYLE_BG, &rollerbg_style);
	lv_roller_set_style(minute_roller, LV_ROLLER_STYLE_SEL, &rollersel_style);
	lv_roller_set_options(minute_roller, MinuteBuf, LV_ROLLER_MODE_INIFINITE);
	lv_roller_set_visible_row_count(minute_roller, 3);
	lv_obj_set_event_cb(minute_roller, hue_select_event_cb);
	lv_obj_set_pos(minute_roller, 197, 68);
## Screenshot and/or video
![IMG_5290|322x392](upload://xD3QuVbLOoYOheymizDGXQY466j.png)
##I want like following:
![IMG_5289|195x147](upload://y5Md2wZv7KdZOJkkyKTgrVURJM1.png)
It’s a limitation in the current version. The selected font needs to be the same as the background font.
I’m very thank you gei me answer and I’m very sorry for too late respond,for too much overtime rencently.
I have set too font style for roller,one for rollerbgstyle the other for rollerselstyle,but the selected and unselect text’s font size just as the rollerbgstyle .No matter how i change the two style they are only one style.
Does the DEV7.0 support change select font size?
No. It’s stil not supported in v7.
Would you consider supporting this feature in subsequent versions?
It’s already added. You can set a larger font for LV_ROLLER_PART_SELECTED.
When I tried it I’ve noticed a small bug and fixed it. So be sure to use the latest master version.
Thank you very much ,I will try it. :smiley:I am very admire your serious attitude
