Before posting
8.3
I made a chart with micro python.
add code
chart.set_style_outline_color( lv.color_hex(0x0002FF), lv.PART.KNOB | lv.STATE.DEFAULT )
chart.set_style_outline_opa(255, lv.PART.KNOB| lv.STATE.DEFAULT )
chart.set_style_outline_width( 1, lv.PART.KNOB | lv.STATE.DEFAULT )
chart.set_style_outline_pad( 0, lv.PART.KNOB | lv.STATE.DEFAULT )
##### startup script #####
import lvgl as lv
import display_driver
##### main script #####
def draw_event_cb(e):
dsc = lv.obj_draw_part_dsc_t.__cast__(e.get_param())
if dsc.part == lv.PART.TICKS and dsc.id == lv.chart.AXIS.PRIMARY_X:
time = ["01", "02", "03", "04", "05", "06", "07", "08", "09", "10", "11", "12","13","14","15","16","17","18","19","20","21","22","23","24"]
dsc.text = bytes(time[dsc.value],"ascii")
# Add ticks and labels to the axis and demonstrate scrolling
style = lv.style_t()
style.init()
style.set_outline_color(lv.palette_main(lv.PALETTE.BLUE))
style.set_outline_width(2)
style.set_outline_pad(8)
# Create a chart
chart = lv.chart(lv.scr_act())
chart.set_size(350, 150)
chart.center()
chart.set_type(lv.chart.TYPE.BAR)
chart.set_style_pad_column(1, 0)
chart.set_range(lv.chart.AXIS.PRIMARY_Y, 0, 100)
chart.set_point_count(24)
chart.add_event_cb(draw_event_cb, lv.EVENT.DRAW_PART_BEGIN, None)
# Add ticks and label to every axis
chart.set_axis_tick(lv.chart.AXIS.PRIMARY_X, 0, 0, 24, 1, True, 24)
# Zoom in a little in X
#chart.set_zoom_x(300)
# Add two data series
ser1 = lv.chart.add_series(chart, lv.palette_lighten(lv.PALETTE.GREEN,1), lv.chart.AXIS.PRIMARY_Y)
#ser1 = lv.chart.add_series(chart, lv.palette_main(lv.PALETTE.BLUE, lv.chart.AXIS.PRIMARY_Y)
#chart.add_style(style, 0)
# Set the next points on 'ser1'
chart.set_next_value(ser1,00)
chart.set_next_value(ser1,10)
chart.set_next_value(ser1,20)
chart.set_next_value(ser1,30)
chart.set_next_value(ser1,40)
chart.set_next_value(ser1,50)
chart.set_next_value(ser1,60)
chart.set_next_value(ser1,70)
chart.set_next_value(ser1,80)
chart.set_next_value(ser1,90)
chart.refresh() # Required after direct set
I can not read&write English very well.
I am relying on google translator.
I’m using MicroPython right now, but I’m planning to use C.
I’d appreciate it if you could tell me what needs to be fixed in both MicroPython and C.
Thx
