How to change the list's text height
Before posting
esp32
8.2
below is the code I write
I found that the height of text “list title” is so small
is there anyway to set is high
void my_demo(void)
	lv_obj_t * obj_list lv_list_creat(lv_scr_act());
	lv_obj_t *_title = lv_list_add_text(obj_list, "Title");
	btn = lv_list_add_btn(list1, LV_SYMBOL_FILE, "New");
    lv_obj_add_event_cb(btn, event_handler, LV_EVENT_CLICKED, NULL);
    btn = lv_list_add_btn(list1, LV_SYMBOL_DIRECTORY, "Open");
    btn = lv_list_add_btn(list1, LV_SYMBOL_SAVE, "Save");
    btn = lv_list_add_btn(list1, LV_SYMBOL_CLOSE, "Delete");
    btn = lv_list_add_btn(list1, LV_SYMBOL_EDIT, "Edit");
Hi @Kingwulin ,
To change the text height you would need to set a bigger font size.
So taking your example it would be something like this:
void my_demo(void)
	lv_obj_t *btn;
	lv_obj_t *obj_list = lv_list_create(lv_scr_act());
    /* Increase size of font for the list */
	lv_obj_set_style_text_font(obj_list,  &lv_font_montserrat_20, LV_PART_MAIN);
	btn = lv_list_add_btn(obj_list, LV_SYMBOL_FILE, "New");
    btn = lv_list_add_btn(obj_list, LV_SYMBOL_DIRECTORY, "Open");
    btn = lv_list_add_btn(obj_list, LV_SYMBOL_SAVE, "Save");
    btn = lv_list_add_btn(obj_list, LV_SYMBOL_CLOSE, "Delete");
    btn = lv_list_add_btn(obj_list, LV_SYMBOL_EDIT, "Edit");
I hope that helps…
Kind Regards,
Pete
