Before posting
Any
v7.02
change color
spinbox = lv_spinbox_create(lv_scr_act(), NULL);
lv_spinbox_set_range(spinbox, -1000, 90000);
lv_spinbox_set_digit_format(spinbox, 5, 2);
lv_spinbox_step_prev(spinbox);
lv_obj_set_width(spinbox, 100);
lv_obj_align(spinbox, NULL, LV_ALIGN_CENTER, 0, 0);
