How to change chart's bg line
Before posting
nrf/zephy
lVGL 8.2
I want to change the color of the line.
i find documents
    lv_obj_t * chart;
    chart = lv_chart_create(ui_bazal_screen);
    lv_obj_set_size(chart, 350, 50);
    lv_obj_center(chart);
    lv_obj_set_y(chart, -50);
    lv_chart_set_type(chart, LV_CHART_TYPE_BAR);
    lv_chart_set_range(chart, LV_CHART_AXIS_PRIMARY_Y, 10, 100);
    lv_chart_set_point_count(chart, 24);
    lv_obj_set_style_bg_opa(chart, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
    lv_obj_set_style_border_opa(chart, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
    lv_chart_set_axis_tick(chart, LV_CHART_AXIS_PRIMARY_Y, 0, 0, 10, 1, true, 0);
I want to change the color of these
Can you tell me what I need to add?
Thx
It’s the lv_obj_set_style_line_color(chart, color, LV_PART_MAIN | LV_STATE_DEFAULT); property.
See Chart (lv_chart) — LVGL documentation
Thank you for always helping me inexperienced :+1:
