How to arrange ROLLER with very long list of options?
Before posting
My code adds large list of options to ROLLER, maybe 100 or 200 options, which significantly increase the whole lag of the system, the larger the list, the more lag!
Is there any option for the roller to read and display only snippets of the whole list of options (only those who are displayed, so the lag be more appropriate?
ESP32
8.3
Faster refresh for ROLLER
Everything I can think of
char buf[5000];
  buf[0] = '\0';
  for (int rName=pIndex; rName<pEnd; rName++) {
    strcat(buf,rife_name[rName]);
    strcat(buf,"\n");
  lv_roller_set_options(ui_Roller1,buf,LV_ROLLER_MODE_NORMAL);
## Screenshot and/or video
I too would like this ability. I have a list of timezones with 461 options. I tried Roller, List, Dropdown… they all lag or just crash. Many UI frameworks have an event to fetch the next item off screen, that could eliminate this issue if implemented.
The tradeoff of going what you want would be memory. each item in the list would have to be a separate lv_label object and that would cost memory to do especially with long lists.
I had thought about the same thing and IDK if it would be possible on all MCUs because of the memory needed to do it. I have made lists on the roller with 340 items and on the ESP32 the roller moves fine without any lag or issues.
