Before posting
master
branch.- Be sure you have checked the FAQ and read the relevant part of the documentation.
Simulator
I’m tryng to create some rectanglular outlines (with shifted perspective) that fill with color to indicate things. I have the shapes working but not sure how to update the canvas after an event.
The plan is to fill these outlines with canvas polygons but I can’t get these to draw based on an event and also not sure how to remove them just leaving the outlines aswell.
I also can’t work out how to get click events via mouse detected using a simulator, using WSL2 on windows 11
lv_obj_t * layer_shape(lv_obj_t * parent){
lv_draw_rect_dsc_t rect_dsc;
lv_draw_rect_dsc_init(&rect_dsc);
rect_dsc.bg_opa = LV_OPA_60;
rect_dsc.bg_color = lv_color_black();//lv_palette_lighten(LV_PALETTE_RED, 4);
rect_dsc.blend_mode = LV_BLEND_MODE_ADDITIVE;
lv_draw_line_dsc_t draw_dsc_main, draw_dsc_outer, draw_dsc_inner;
lv_draw_line_dsc_init(&draw_dsc_main);
lv_draw_line_dsc_init(&draw_dsc_outer);
lv_draw_line_dsc_init(&draw_dsc_inner);
set_main_draw_line_style(&draw_dsc_main);
set_offset_draw_line_style(&draw_dsc_outer);
set_offset_draw_line_style(&draw_dsc_inner);
static lv_color_t cbuf[LV_CANVAS_BUF_SIZE_TRUE_COLOR(CANVAS_WIDTH, LAYER_SHAPE_HEIGHT + 5)];
lv_obj_t * canvas = lv_canvas_create(parent);
lv_obj_add_flag(canvas, LV_OBJ_FLAG_CLICKABLE);
//lv_obj_set_click(canvas, true);
lv_canvas_set_buffer(canvas, cbuf, CANVAS_WIDTH ,LAYER_SHAPE_HEIGHT + 5, LV_IMG_CF_TRUE_COLOR_ALPHA);
lv_canvas_fill_bg(canvas, lv_palette_darken(LV_PALETTE_GREY, 1), LV_OPA_TRANSP);
//lv_obj_add_style(canvas, &main_draw_line_style, 0);
//lv_obj_align(canvas, LV_ALIGN_RIGHT_MID,0 ,0);
// lv_canvas_draw_rect(canvas, 10, 10, 20, 20, &rect_dsc);
lv_point_t left = {5, (LAYER_SHAPE_HEIGHT / 2)+ 2.5};
lv_point_t top = {(LAYER_SHAPE_WIDTH / 2 ) + 5,2.5};
lv_point_t right = {LAYER_SHAPE_WIDTH + 5,(LAYER_SHAPE_HEIGHT / 2)+ 2.5};
lv_point_t bottom = {(LAYER_SHAPE_WIDTH / 2 ) + 5,LAYER_SHAPE_HEIGHT + 2.5};
const lv_point_t points[4] = {left, top, right,
bottom};
lv_canvas_draw_polygon(canvas, points, 4,&rect_dsc);
const lv_point_t main_line_points[5] = {left,top,right,bottom,left};
const lv_point_t outer_line_points[5] = {{left.x - LINE_OFFSET, left.y }, translate_point(top, 0, -LINE_OFFSET),translate_point(right,LINE_OFFSET, 0),
translate_point(bottom,0,LINE_OFFSET) , {left.x - LINE_OFFSET, left.y }};
const lv_point_t inner_line_points[5] = {translate_point(left,LINE_OFFSET,0), translate_point(top, 0, LINE_OFFSET),translate_point(right,-LINE_OFFSET, 0),
translate_point(bottom,0,-LINE_OFFSET) , translate_point(left,LINE_OFFSET,0)};
lv_canvas_draw_line(canvas, outer_line_points,5, &draw_dsc_outer);
lv_canvas_draw_line(canvas, inner_line_points,5, &draw_dsc_inner);
lv_canvas_draw_line(canvas, main_line_points, 5, &draw_dsc_main);
lv_area_t blur_area = {
4, 1, LAYER_SHAPE_WIDTH + 6, LAYER_SHAPE_HEIGHT + 4
lv_canvas_blur_hor(canvas, &blur_area, 1.5);
lv_canvas_blur_ver(canvas, &blur_area, 1.5)
lv_obj_add_flag(canvas, LV_OBJ_FLAG_EVENT_BUBBLE);
return canvas;
lv_obj_t * layer_indicators(lv_obj_t * parent){
static lv_color_t cbuf[LV_CANVAS_BUF_SIZE_TRUE_COLOR(CANVAS_WIDTH, CANVAS_HEIGHT)];
lv_canvas_set_buffer(canvas, cbuf, CANVAS_WIDTH ,CANVAS_HEIGHT, LV_IMG_CF_TRUE_COLOR_CHROMA_KEYED);
lv_canvas_fill_bg(canvas, lv_color_black(), LV_OPA_100);
lv_obj_align(canvas, LV_ALIGN_TOP_LEFT,4 ,4);
lv_img_dsc_t * img ;
img = lv_canvas_get_img(layer_shape(canvas));
for(int i = 0;i < 5; i++){
lv_canvas_transform(canvas, img,0,256, 0,(4 * 10) - ( i * 10),0 ,0, false);
static lv_color_t cbuf_tmp[CANVAS_WIDTH * CANVAS_HEIGHT];
memcpy(cbuf_tmp, cbuf, sizeof(cbuf_tmp));
img->data = (void *)cbuf_tmp;
lv_obj_add_event_cb(canvas, layer_change_cb,LV_EVENT_PRESSED, NULL );
lv_obj_add_event_cb(canvas, layer_change_cb,LV_EVENT_CLICKED, NULL );
return canvas;
