How do I change the size of LV SYMBOL
Before posting
  • Be sure you have checked the relevant part of the documentation. We will not respond in detail to posts where you haven’t read the relevant documentation.
STM32
V7.0
change size.
lv_obj_set_size();
lv_obj_t * label = lv_label_create(lv_scr_act(),NULL);
lv_label_set_text(label,LV_STMBOL_WARNING);
lv_obj_set_size(label,30,30);
static lv_style_t style
lv_style_init(&style);
lv_style_set_text_font(&style,LV_STATE_DEFAULT,&lv_font_montserrat_28);
As you’ve discovered, labels (by default) do not allow their size to be changed using the standard functions. This is because the default long mode controls the label’s size itself.
If you do want to customize the label’s size, you can choose a different mode (like LV_LABEL_LONG_CROP or LV_LABEL_LONG_BREAK).
Thank you very much,
You want to change the lable’s size ,right?
Not the SYMBOL size.
I am trying to change the SYMBOL size on this topic. I have multiple labels that contain some of the fontAwesome special characters (LV_SYMBOL_UP, LV_SYMBOL_DOWN, LV_SYMBOL_LEFT, LV_SYMBOL_RIGHT) … I am using these as navigation indicators, but I am wanting to change the size of these symbols. Is this possible?
any update on this?
i’ve created different fonts with my symbols at different sizes, but i can’t actually use at the same time, as the variable glyph_bitmap is already defined …
Could be nice to resize without creating every time a new icon set into a new font.
You cannot. Symbols are text fonts, if you want a bigger symbol you will have to create another font with larger symbols in it.
this is now clear!Unfortunally i’m facing issue when try to use more than one custom font… :confused:
In that case… please open a new topic
