How can I screen refresh?
Before posting
STM32
8.3.6
I’m experiencing a phenomenon where an event is triggered and the Text or obj whose style is changed is broken.
temporarily
lv_obj_add_flag(ui_Screen, LV_OBJ_FLAG_HIDDEN);
lv_obj_clear_flag(ui_Screen, LV_OBJ_FLAG_HIDDEN);
If I call and refresh it, it works to some extent and I am using it. Is there any way to refresh the entire screen in LVGL itself?
I am using this to call the function that triggers the event.
void refesh()
use to redraw the whole object/screen
lv_obj_invalidate(ui_Screen);
// or
lv_obj_invalidate(lv_screen_active()); // redraw the current active screen
