Before posting
STM32
8.3.6
for example
lv_obj_clean(parent of A) ; When using the function that changes the text of A on another screen after use, the error was handled by checking the existence of A by looking at A.class_p.
However, lv_obj_clean(parent of B); After using lv_arc_set_range(B, 0, value) and then using lv_arc_set_value(B, gauge_value), B.class_p automatically creates lv_label_class and no error occurred.
I am asking a question because I wonder if the existence of obj is judged by class_p.
Is there any way to check if obj exists?
I’ve tried lv_obj_del & lv_obj_clean.
void create()
parent_B = lv_obj_create(ui_Screen1);
parent_A = lv_obj_create(ui_Screen1);
A = lv_label_create(parent_A );
B= lv_arc_create(parent_B );
void clean()
lv_obj_clean(parent_B);
lv_obj_clean(parent_A);
void check()
if(A->class_p != 0) // A.class_p == 0;
if(B->class_p != 0) // B.class_p == 0x80c5128 <lv_label_class>
Briefly, I used the code like this.
