Help in getting a button click to increment a roller
Before posting
  • Read the
Need help with Button click to increment Roller
Win32 Simulator
I want to be able to click on a button which then increments a roller widget.
static void event_handlerHour(lv_event_t* e2)
    lv_event_code_t code = lv_event_get_code(e2);
    lv_obj_t* obj2 = (lv_obj_t*)lv_event_get_target(e2);
    if (code == LV_EVENT_VALUE_CHANGED) {
        char buf[32];
        lv_roller_get_selected_str(obj2, buf, sizeof(buf));
        LV_LOG_USER("Selected hour: %s\n", buf);
 * An infinite roller with the name of the months
void lv_hour_roller(void)
    lv_obj_t* roller1 = lv_roller_create(lv_scr_act());
    lv_roller_set_options(roller1,
        "01\n""02\n""03\n""04\n""05\n""06\n""07\n""08\n""09\n""10\n""11\n""12",
        LV_ROLLER_MODE_INFINITE);
    lv_roller_set_visible_row_count(roller1, 5);
    lv_obj_align(roller1, LV_ALIGN_CENTER, 0, 0);
    lv_obj_add_event(roller1, event_handlerHour, LV_EVENT_KEY, NULL);
static void event_handler(lv_event_t* e)
    if (code == LV_EVENT_CLICKED) {
        LV_LOG_USER("Clicked");
        lv_obj_send_event(obj2, LV_EVENT_CLICKED, NULL); // ERROR HERE, OBJ2 not defined
    else if (code == LV_EVENT_VALUE_CHANGED) {
        LV_LOG_USER("Toggled");
void lv_button(void)
    lv_obj_t* label;
    lv_obj_t* btn1 = lv_btn_create(lv_scr_act());
    lv_obj_align(btn1, LV_ALIGN_BOTTOM_MID, 0, -25);
    lv_obj_add_event(btn1, event_handler, LV_EVENT_CLICKED, NULL);
    label = lv_label_create(btn1);
    lv_label_set_text(label, "Up");
    lv_obj_center(label);
There error is in the event_handler(). OBJ2 is not defined. What is supposed to go here?
I guess I don’t understand how the “lv_obj_send_event()” function is supposed to work. Is there another way to send a button click to the roller? If there is, can some kind soul point me to the part in the docs that explains it? Or maybe an example?
Thanks,
Richard.
You can do this in the button’s click event:
lv_roller_set_selected(roller, lv_roller_get_selected(roller) + 1, LV_ANIM_ON);
Thank you so much for pointing me in the proper direction.
I do have one issue. I am getting an error when I use your suggested line of code " ```
The error message says:
lv_roller_get_selected: Asserted at expression: obj != NULL (The object is NULL)
When I try "uint16_t current_hour = lv_roller_get_selected(roller1);" I get the same error.
I don't know if this makes a difference or not but I'm using the Win32 simulator.
Any ideas what is wrong?  Thanks again,
Richard
This works for me in lvgl v9
lv_obj_t* roller;
        char buf[32];
static void button_event_handler(lv_event_t* e)
int main () {
   /* Setup */
  roller = lv_roller_create(lv_scr_act());
  lv_roller_set_options(roller,
  lv_roller_set_visible_row_count(roller, 5);
  lv_obj_align(roller, LV_ALIGN_CENTER, 0, 0);
  lv_obj_add_event(roller, event_handlerHour, LV_EVENT_KEY, NULL);
  lv_obj_t* label;
  lv_obj_add_event(btn1, button_event_handler, LV_EVENT_CLICKED, NULL);
  /* Infinite loop */
Thanks Carlos. You saved me a ton frustration.
