Before posting
master branch.
- Be sure you have checked the relevant part of the documentation. We will not respond in detail to posts where you haven’t read the relevant documentation.
how to get swipe direction
simulator
7.4.0
get swipe direction when drag on touch panel
i tried print event in tileview callback function.
event: 8
event: 16
event: 9
event: 10
event: 8
event: 16
event: 9
event: 10
event: 8
event: 16
event: 9
event: 10
event: 8
event: 16
event: 9
event: 10
event: 8
event: 16
event: 9
event: 10
it’s mean,
LV_EVENT_DRAG_BEGIN
LV_EVENT_VALUE_CHANGED
LV_EVENT_DRAG_END
LV_EVENT_DRAG_THROW_BEGIN
i cannot get direction of swipe.
please help.
Hi @nguyennamdsn ,
I think this post will help you achieve your goal.
Kind Regards,
Pete
thank you.
i tried it before start this post. but no LV_EVENT_GESTURE event.
only
LV_EVENT_DRAG_BEGIN
LV_EVENT_DRAG_END
occur when swipe.
i try with bellow code and can get the direction.
____if (event == LV_EVENT_DRAG_BEGIN) {
________lv_indev_t * indev = lv_indev_get_act();
________if (indev != NULL){
____________if (indev->proc.types.pointer.drag_dir == LV_DRAG_DIR_HOR) {
________________if (indev->proc.types.pointer.vect.x > 0) {
____________________print_log(“Left to right\n”);
________________}else if (indev->proc.types.pointer.vect.x < 0) {
____________________print_log(“Right to left\n”);
________________}
____________}else if (indev->proc.types.pointer.drag_dir == LV_DRAG_DIR_VER) {
________________if (indev->proc.types.pointer.vect.y > 0) {
____________________print_log(“Up to down\n”);
________________}
________________else if (indev->proc.types.pointer.vect.y < 0) {
____________________print_log(“Down to up\n”);
________________}
____________}
________}
____}
but i don’t known is this right manner.
and once more question. how do i get coordinate of start drag and stop drag ?
Hi @nguyennamdsn ,
Are you definitely assigning the event handler to lv_scr_act()?
Can you confirm that this simple example works in the simulator for you:
void scr_event_cb(lv_obj_t * obj, lv_event_t e)
if(e == LV_EVENT_GESTURE) {
lv_gesture_dir_t dir = lv_indev_get_gesture_dir(lv_indev_get_act());
printf("Dir: %d\n\r", dir);
fflush(stdout);
int main(int argc, char **argv)
(void)argc; /*Unused*/
(void)argv; /*Unused*/
/*Initialize LVGL*/
/*Initialize the HAL (display, input devices, tick) for LVGL*/
hal_init();
// lv_demo_widgets();
// lv_demo_printer();
lv_obj_set_event_cb(lv_scr_act(), scr_event_cb);
while (1) {
/* Periodically call the lv_task handler.
* It could be done in a timer interrupt or an OS task too.*/
lv_task_handler();
usleep(5 * 1000);
return 0;
The output I get from the console for the above code is:
Dir: 3
Dir: 2
Dir: 0
Dir: 1
Dir: 2
used: 5080 ( 8 %), frag: 2 %, biggest free: 59288
Dir: 3
Dir: 0
Dir: 1
Dir: 0
Dir: 1
used: 5072 ( 8 %), frag: 1 %, biggest free: 60448
Dir: 0
Dir: 1
Dir: 3
Dir: 2
as I click and swipe in various directions with the mouse cursor.
Kind Regards,
Pete
The gesture event wasn’t sent before v7.4 if the objects were dragged. However, it was changed in v7.4. See the changelog.
Are you sure you are using the v7.4?
In earlier versions this line prevented sending gesture while dragging. You can check if it’s there for you.
