Before posting
masterbranch.- Read the
I’m new to lvgl and tried to do some modification on the demo files. And this fits. Now I’m tried to do some more modification and run in a problem.
I generate just an object and set values for height, width and position. For simualtion is set display size 240x320. In simulation I can see an empty “body” at the expected position and with the expected size.
But when I read back the width and height of the object, I get 0 as height and width.
In cause of the “right looking” in simulation, I would expect to see the values in the object by debugger. But there is nothing to see. So I’m confused.
The nearly same code is used in lvgl-academy in the widget-base-object
WindowsSimulation, VisualStudio22
I would expect to see the setted values, if I use the lv_obj_get_height or _width
lv_obj_t* obj1 = lv_obj_create(lv_scr_act());
lv_obj_set_width(obj1, 50);
lv_obj_set_height(obj1, 50);
lv_obj_set_pos(obj1, 100, 100);
lv_coord_t w = lv_obj_get_width(obj1);
lv_coord_t h = lv_obj_get_height(obj1);
printf("width = %d, height = %d\n", w,h);
The output:
width = 0, height = 0
