Even if you do lv_obj_del(), you continue to use memory
Before posting
Arduino ESP32-S3
8.3
Hi.
I’m creating a UI that represents the weather.
However, if you remove the UI for weather updates and display it again, it takes up memory.
Below is my implementation code.
lv_obj_t * panel;
lv_obj_t * panel1;
lv_obj_t * First_day;
lv_obj_t * Second_day;
lv_obj_t * Third_day;
lv_obj_t * Fourth_day;
void Weather(WeatherData data){
  static lv_style_t Weather_style;
  lv_style_init(&Weather_style);
  lv_style_set_bg_opa(&Weather_style, LV_OPA_COVER);
  lv_style_set_bg_color(&Weather_style, lv_color_white());
  lv_style_set_border_color(&Weather_style, lv_palette_main(LV_PALETTE_ORANGE));
  lv_style_set_border_width(&Weather_style, 2);
  lv_style_set_border_side(&Weather_style, LV_BORDER_SIDE_TOP | LV_BORDER_SIDE_BOTTOM | LV_BORDER_SIDE_LEFT);
  panel = lv_obj_create(lv_scr_act());
  lv_obj_remove_style_all(panel);
  lv_obj_set_size(panel, 60, 380);
  lv_obj_set_pos(panel, 0, 0);
  lv_obj_add_style(panel, &Weather_style, 0);
  for(int i = 0; i < 6; i++){
    lv_obj_t *Weather_Text = lv_label_create(panel);
    if(i == 0){
      lv_label_set_text(Weather_Text, "μ‹œκ°");
      lv_obj_set_style_text_align(Weather_Text, LV_TEXT_ALIGN_CENTER, 0);
      lv_obj_align(Weather_Text, LV_ALIGN_CENTER, 0, -140);
    if(i == 1){
      lv_label_set_text(Weather_Text, "날씨");
      lv_obj_align(Weather_Text, LV_ALIGN_CENTER, 0, -90);
    if(i == 2){
      lv_label_set_text(Weather_Text, "기온");
      lv_obj_align(Weather_Text, LV_ALIGN_CENTER, 0, -10);
    if(i == 3){
      lv_label_set_text(Weather_Text, "μŠ΅λ„");
      lv_obj_align(Weather_Text, LV_ALIGN_CENTER, 0, 60);
    if(i == 4){
      lv_label_set_text(Weather_Text, "κ°•μˆ˜λŸ‰\n(mm)");
      lv_obj_align(Weather_Text, LV_ALIGN_CENTER, 0, 110);
    if(i == 5){
      lv_label_set_text(Weather_Text, "κ°•μˆ˜\nν™•λ₯ ");
      lv_obj_align(Weather_Text, LV_ALIGN_CENTER, 0, 160);
  static lv_style_t Weather_Value_Style;
  lv_style_init(&Weather_Value_Style);
  lv_style_set_bg_opa(&Weather_Value_Style, LV_OPA_COVER);
  lv_style_set_bg_color(&Weather_Value_Style, lv_color_white());
  lv_style_set_border_color(&Weather_Value_Style, lv_palette_main(LV_PALETTE_ORANGE));
  lv_style_set_border_width(&Weather_Value_Style, 0);
  lv_style_set_border_side(&Weather_Value_Style, LV_BORDER_SIDE_RIGHT | LV_BORDER_SIDE_TOP | LV_BORDER_SIDE_BOTTOM);
  panel1 = lv_obj_create(lv_scr_act());
  lv_obj_remove_style_all(panel1);
  lv_obj_set_size(panel1, 420, 380);
  lv_obj_set_pos(panel1, 60, 0);
  lv_obj_add_style(panel1, &Weather_Value_Style, 0);
  lv_obj_set_scroll_dir(panel1, LV_DIR_LEFT | LV_DIR_RIGHT);
  static lv_style_t chart_style;
  lv_style_init(&chart_style);
  lv_style_set_border_color(&chart_style, lv_color_white());
  lv_obj_t * chart;
  chart = lv_chart_create(panel1);
  lv_chart_set_div_line_count(chart, 0, 0);
  lv_obj_set_pos(chart, 15, 120);
  lv_obj_add_style(chart, &chart_style, 0);
  lv_chart_series_t * ser1 = lv_chart_add_series(chart, lv_palette_main(LV_PALETTE_BLUE), LV_CHART_AXIS_PRIMARY_Y);
  lv_chart_set_point_count(chart, 72);
  lv_chart_set_type(chart, LV_CHART_TYPE_LINE);
  lv_obj_set_size(chart, 4285, 110);
  lv_chart_set_range(chart, LV_CHART_AXIS_PRIMARY_Y, data.low_temp, data.high_temp); //Use the maximum and minimum temperatures to specify the range of charts
  lv_obj_clear_flag(chart, LV_OBJ_FLAG_SCROLLABLE);
  lv_chart_set_update_mode(chart, LV_CHART_UPDATE_MODE_CIRCULAR);
  int32_t pad_left = lv_obj_get_style_pad_left(chart, 0);
  lv_obj_update_layout(chart);
  int clock_zero_count = 0;
  int Axis_X = -180;
  for(int i = 0; i < 72; i++){
    if(i != 0)Axis_X += 60;
    if(data.Hour_data[i] == 0){
      if(clock_zero_count == 2){
        clock_zero_count = 3;
        third_axis = Axis_X + 170;
      if(clock_zero_count == 1){
        clock_zero_count = 2;
        second_axis = Axis_X + 170;
      if(clock_zero_count == 0){
        clock_zero_count = 1;
        first_axis = Axis_X + 170;
        if(first_axis > 200)first_vision = true;
    lv_obj_t *Weather_Value_Time_Text = lv_label_create(panel1);
    lv_label_set_text_fmt(Weather_Value_Time_Text, "%dμ‹œ", data.Hour_data[i]);
    lv_obj_set_style_text_align(Weather_Value_Time_Text, LV_TEXT_ALIGN_CENTER, 0);
    lv_obj_align(Weather_Value_Time_Text, LV_ALIGN_CENTER, Axis_X, -140);
    lv_obj_t *Weather_Value_Img = lv_img_create(panel1);
    if(data.Weather_data[i] == 1){
      if(data.Hour_data[i] < 8 || data.Hour_data[i] > 17)lv_img_set_src(Weather_Value_Img, &Clear_N);
      else lv_img_set_src(Weather_Value_Img, &Clear_S);
    if(data.Weather_data[i] == 2){
      if(data.Hour_data[i] < 8 || data.Hour_data[i] > 17)lv_img_set_src(Weather_Value_Img, &Mostly_Cloudy_N);
      else lv_img_set_src(Weather_Value_Img, &Mostly_Cloudy_S);
    if(data.Weather_data[i] == 3)lv_img_set_src(Weather_Value_Img, &Cloudy);
    if(data.Weather_data[i] == 4)lv_img_set_src(Weather_Value_Img, &Rain);
    if(data.Weather_data[i] == 5)lv_img_set_src(Weather_Value_Img, &Rain_Snow);
    if(data.Weather_data[i] == 6)lv_img_set_src(Weather_Value_Img, &Snow);
    if(data.Weather_data[i] == 7)lv_img_set_src(Weather_Value_Img, &shower);
    if(data.Weather_data[i] == 8)lv_img_set_src(Weather_Value_Img, &Raindrop);
    if(data.Weather_data[i] == 9)lv_img_set_src(Weather_Value_Img, &Raindrop_Snow);
    if(data.Weather_data[i] == 10)lv_img_set_src(Weather_Value_Img, &Snow_Drifting);
    lv_obj_align(Weather_Value_Img, LV_ALIGN_CENTER, Axis_X, -90);
    lv_obj_t *Weather_Value_Humidity_Text = lv_label_create(panel1);
    lv_label_set_text_fmt(Weather_Value_Humidity_Text, "%d%%", data.Humidity_data[i]);
    lv_obj_set_style_text_align(Weather_Value_Humidity_Text, LV_TEXT_ALIGN_CENTER, 0);
    lv_obj_align(Weather_Value_Humidity_Text, LV_ALIGN_CENTER, Axis_X, 60);
    lv_obj_t *Weather_Value_Rain_Text = lv_label_create(panel1);
    float rain = data.Rain_data[i];
    if(rain == 0)lv_label_set_text(Weather_Value_Rain_Text, "-");
    if(rain > 0 && rain < 1)lv_label_set_text(Weather_Value_Rain_Text, "~1");
    if(rain >= 1){
      char rain_str[10];
      if (rain == static_cast<int>(rain))snprintf(rain_str, sizeof(rain_str), "%d", static_cast<int>(rain));
      else dtostrf(rain, 4, 1, rain_str);
      const char* rain_const = rain_str;
      lv_label_set_text(Weather_Value_Rain_Text, rain_const);
    lv_obj_set_style_text_align(Weather_Value_Rain_Text, LV_TEXT_ALIGN_CENTER, 0);
    lv_obj_align(Weather_Value_Rain_Text, LV_ALIGN_CENTER, Axis_X, 110);
    lv_obj_t *Weather_Value_Rain_Per_Text = lv_label_create(panel1);
    lv_label_set_text_fmt(Weather_Value_Rain_Per_Text, "%d%%", data.Rain_Per_data[i]);
    lv_obj_set_style_text_align(Weather_Value_Rain_Per_Text, LV_TEXT_ALIGN_CENTER, 0);
    lv_obj_align(Weather_Value_Rain_Per_Text, LV_ALIGN_CENTER, Axis_X, 160);
    lv_chart_set_next_value(chart, ser1, data.Temp_data[i]);
    lv_point_t p;
    lv_chart_get_point_pos_by_id(chart, ser1, i, &p);
    lv_obj_t *Weather_Temp_Text = lv_label_create(chart);
    lv_label_set_text_fmt(Weather_Temp_Text, "%d", data.Temp_data[i]);
	  lv_obj_set_style_text_align(Weather_Temp_Text, LV_TEXT_ALIGN_CENTER, 0);
	  lv_obj_set_width(Weather_Temp_Text, 50);
    if(data.Temp_data[i] == data.high_temp || data.Temp_data[i] == data.second_temp || data.Temp_data[i] == data.third_temp)lv_obj_set_pos(Weather_Temp_Text, p.x - 25 - pad_left, p.y - 5);
	  else lv_obj_set_pos(Weather_Temp_Text, p.x - 26 - pad_left, p.y - 35);
  static lv_style_t style;
  lv_style_init(&style);
  lv_style_set_radius(&style, 5);
  lv_style_set_bg_opa(&style, LV_OPA_COVER);
  lv_style_set_bg_color(&style, lv_palette_main(LV_PALETTE_BLUE));
  lv_style_set_border_width(&style, 1);
  lv_style_set_border_color(&style, lv_palette_main(LV_PALETTE_BLUE));
  lv_style_set_pad_all(&style, 5);
  lv_style_set_text_color(&style, lv_color_white());
  if(first_axis > 200){
    First_day = lv_label_create(panel1);
    lv_obj_add_style(First_day, &style, 0);
  Second_day = lv_label_create(panel1);
  lv_obj_add_style(Second_day, &style, 0);
  Third_day = lv_label_create(panel1);
  lv_obj_add_style(Third_day, &style, 0);
  Fourth_day = lv_label_create(panel1);
  lv_obj_add_style(Fourth_day, &style, 0);
  for(int i = 0; i < 4; i++){
    String day = cal_time(i);
    char buf[day.length() + 1];
    day.toCharArray(buf, day.length() + 1);
    if(i == 0 && first_vision == true){
      lv_label_set_text(First_day, buf);
      lv_obj_set_style_text_align(First_day, LV_TEXT_ALIGN_CENTER, 0);
      lv_obj_set_pos(First_day, 0, 4);
      lv_obj_update_layout(First_day);
    if(i == 1){
      lv_label_set_text(Second_day, buf);
      lv_obj_set_style_text_align(Second_day, LV_TEXT_ALIGN_CENTER, 0);
      lv_obj_set_pos(Second_day, first_axis, 4);
      lv_obj_update_layout(Second_day);
    if(i == 2){
      lv_label_set_text(Third_day, buf);
      lv_obj_set_style_text_align(Third_day, LV_TEXT_ALIGN_CENTER, 0);
      lv_obj_set_pos(Third_day, second_axis, 4);
      lv_obj_update_layout(Third_day);
    if(i == 3){
      lv_label_set_text(Fourth_day, buf);
      lv_obj_set_style_text_align(Fourth_day, LV_TEXT_ALIGN_CENTER, 0);
      lv_obj_set_pos(Fourth_day, third_axis, 4);
      lv_obj_update_layout(Fourth_day);
  lv_obj_add_event_cb(panel1, event_cb, LV_EVENT_ALL, NULL);
void Weather_delete(){
  lv_obj_del(panel);
  lv_obj_del(panel1);
void event_cb(lv_event_t * e){
  if(code == LV_EVENT_SCROLL){
    lv_coord_t axis = lv_obj_get_scroll_x(panel1);
    if(first_vision == true)int first_width = lv_obj_get_width(First_day) + 10;
    int second_width = lv_obj_get_width(Second_day) + 10;
    int third_width = lv_obj_get_width(Third_day) + 10;
    int fourth_width = lv_obj_get_width(Fourth_day) + 10;
    if(last_axis > axis){ // Right
      //Serial0.println("right");
      //if(first_axis <= axis && (second_axis - second_width) > axis)lv_obj_set_pos(Second_day, axis, 4);
      //if(second_axis <= axis && third_axis > axis)lv_obj_set_pos(Third_day, axis, 4);
    if(last_axis < axis){ //Left
      Serial0.println("left");
    if(second_axis <= axis && (third_axis - third_width) > axis)lv_obj_set_pos(Third_day, axis, 4);
    last_axis = axis;
    //lv_obj_set_pos(test_Text, axis, 10);
Update and clear the weather UI whenever the count increases by 1.
(Weather() β†’ Weather_delete)
You can see that the Psram memory area decreases each time you run this code.
What am I missing?
at first glance - I think it may have to do with the styles such as chart_style, Weather_style et cetera being initialised every time, I believe these do not get deleted upon deletion of the parent panels. I suggest making your styles constants to store them in ROM and stop them having to be initialized every time:
Look for β€œconst” in the documentation for styles here:
https://docs.lvgl.io/8.3/overview/style.html
omg thx :slight_smile:
Resolved!
