Before posting
masterbranch.- Be sure you have checked the relevant part of the documentation.
ESP32 + ILI9341
7.11
Run the display task on core 0 on a ESP32 with Arduino
- Removed background image
- Verified that on main loop no slowdowns happen
- Removed network tasks out of main loop (Like MQTT updates and wifi manager)
see : GitHub - rvt/espgaggia: Automate your gaggia classic or other machine... · GitHub
When I DISPLAY_TASK_IN_MAIN_LOOP is disabled I am setting up that display updates happen on core 0 of the esp using an FreeRTOS task using xTaskCreatePinnedToCore. When doing this I noticed that my display updates run slow occassionally, this is measured here: espgaggia/src/main.cpp at master · rvt/espgaggia · GitHub
display_loop simply runs lv_task_handler();
Touch messages from the UI and updates from the main loop to the UI are send using a FreeRTOS message queue.
For some time the display updates well within 100ms, but sometimes it takes up to 1000ms (just one time) and you can visibly see the UI updating (top to bottom) and touch becomes slow. Then it runs fast again for a few seconds (this seems rather random…) and then grinds to a halt again for one frame..
https://github.com/rvt/espgaggia/blob/master/src/main.cpp
