Before posting
ESP32-Wrover-E (Flash 16MB, PSRAM 4MB)
8.3.7
Using Firebase and LVGL at the same time
ESP32 is using Firebase and LVGL at the same time
An error called Memory allocation failed occurred
I bought a module with built-in PSRAM knowing that it was an error caused by insufficient Heap.
However, to enable PSRAM, the platform.ini has the following command
When I set and operate build_flags = -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue, watchdogs occur indefinitely.
The same happens when you remove Firebase and use LVGL alone.
Change LV_MEM_CUSTOM to 0 in lv_conf.h through search
#define LV_MEM_POOL_INCLUDE “esp_heap_caps.h”
The #define LV_MEM_POOL_ALLOC(size) heap_caps_malloc(size, MALLOC_CAP_SPIRAM) setting has also been changed. This, too, continues to cause watchdogs.
Is there a problem I’m missing?
lv_conf.h
#define LV_MEM_CUSTOM 0
#if LV_MEM_CUSTOM == 0
#define LV_MEM_SIZE (48U * 1024U) /*[bytes]*/
#if LV_MEM_ADR == 0
#define LV_MEM_POOL_INCLUDE "esp_heap_caps.h"
#else /*LV_MEM_CUSTOM*/
#define LV_MEM_CUSTOM_INCLUDE <stdlib.h> /*Header for the dynamic memory function*/
#define LV_MEM_CUSTOM_ALLOC malloc
#define LV_MEM_CUSTOM_FREE free
#define LV_MEM_CUSTOM_REALLOC realloc
#endif /*LV_MEM_CUSTOM*/
platformio.ini
